Nano sd upload
mcwx1359
Nano sd upload
Post by mcwx1359 »
hi, looking at getting the nano sd to run with my vantage vue to upload to a website, am I right in thinking that the weather34 template which is on the nano can be uploaded directly to a site or is there additional scripts required..
Getting a little confused the more I look into it !
Thanks in advance for any assistance.
Re: Nano sd upload
hello
built in version of weather34 in nanosd is for using internally in the actual meteobridge setup screen itself .the internal nanosd is an older version of weather34 .
if you want to have a weather34 public version on a personal public website then use the version available on request via https://weather34.com/homeweatherstation/
and follow the simple guide
if you need further help then this forum has many knowledgeable users or i can help via email though this is somewhat limited at present .
the website version is aimed and designed to be pretty much setup once and forget and you can use the built in updater to apply small updates which really makes life easy to apply updates again almost click and update approach.
i would follow this thread viewtopic.php?f=56&t=14398&start=810 and join in to get some useful answers from various long term users.
the aim of this template is to allow even the less experienced knowledgeable website user to have a dedicated template just being 95% about your data and not scrape data from websites or rely on third party services to an extent and when they go wrong it screws up your data viewing. simple clean approach...install and forget theoretically..
brian
mcwx1359
Re: Nano sd upload
Post by mcwx1359 »
Brian, thank you, just a point that following the links for the weather34 results in forbidden access ?
Re: Nano sd upload
good morning no idea just checked perhaps you reside on a ip range that is blocked ..where are you i.e which country ?
mcwx1359
Re: Nano sd upload
Post by mcwx1359 »
Brian, i'm in the UK .. odd works ok from work .
I'll try again at home , can't see any reason for it to be forbidden though.
Best Regards
Mike
mcwx1359
Re: Nano sd upload
Post by mcwx1359 »
Brian, well this is odd, never had this issue before, presume must be something on our router or provider. I can access it at work but unable to get into the site at home. Anything I can do here ?
Mike
