Wswin Import - Wrong Rain Data. **solved**
WETRHE
Post by WETRHE »
I am using Meteobridge Pro Red 4.3 (Jun 30 2020, build 13605), FW 1.4 since a few weeks, together with Davis Vantage Pro 2 Aktiv EU Version (connected through USB, directly to the MB). I was working with wswin before. Now I’m trying to import my old wswin data into meteobridge, which is not working perfectly regarding the total rain data. However, I have always a mismatch between the total rain data in wswin and MB. For example: Wswin rain data for this month is 35.7 mm, MB rain data after import says rain sum month is 12.4mm. Wswin rain from yesterday was 0.6 mm and MB says rain sum yesterday is 0.4mm. Davis is setup to 0.2mm calibration, wswin is setup to 0.2mm calibration and MB is also setup to 0.2mm rain calibration. I have also reset all systems to default in order to test but there is also a difference between wswin data and MB.
Wswin shows the correct rain sum since years.
I have tried to import the data using the meteobridge wswin import function (described in the MB Wiki) with the wswin csv exports. But I noticed, that the rain data hasn’t been imported 1:1 Then I started trying to import the data using the direct import function from meteobridge. Therefore I have stored the csv data from wswin into a mysql database and exported it into a textfile regarding the MB Syntax mentioned in the WIKI: <epoch time stamp> <sensor name> <sensor value>. But even then, I got a difference between the rain data from wswin and Meteobridge. Somehow, during the data import, Meteobridge is recalculating or manipulating the data. I would expect, that if I do a RAW Data Import that the data will be imported 1:1 without being manipulated but this isnt’t the case. Can you please help me any further in this regards? Another question would be: Is there any possibility to connect to the MB database via ssh directly to store the data in MB? Would be VERY helpful indeed ;)
Thanks for any advice in advance & best regards
Re: Wswin Import - Wrong Rain Data
Can you please send me a WSWIN file where rain totals do not import properly? Please send to "info(at)meteobridge.com".
WETRHE
Post by WETRHE »
Wswin Rain Data Import is now working fine in Meteobridge 4.4 from Jul 13 2020 - Thanks!
