Issues found after using backup file to restore Meteohub
cbhiii
Post by cbhiii »
I restored my Meteohub from backup and found that some key pieces of information are not contained in the meteohub.backup file.
- IP address in use
- DHCP checkbox state
- DNS IP
- IP Port
- Time zone
- NPT time servers addresses
(also the number of characters in the NTP fields is limited to 24 characters or so which can limit longer server addresses)
Outside of those issues, the backup worked fine.
Re:Issues found after using backup file to restore Meteohub
Thanks for taking your time to write down the areas that have to fixed manually after restoring a backup.
Might be helpful for other users as well.
