wordpress weather station
mcwx1359
Post by mcwx1359 »
anyone managed to sort out an issue with sending realtime.txt from nano sd to this plug in using wordpress .I have got the station set up but getting errors reading the file as below
code 500 2020-07-11 18:25:49
1 min ago
Station Inconsistent data to insert in data table: Array ..
Regards Mike
wsnoordbergum
Re: wordpress weather station
Post by wsnoordbergum »
I'm using the weatherstation plug in on my wordpress site with no problems.
I use the NANO SD version.
I use the HTTP upload of a realtime file called MBrealtime.txt
The file is stored on my webserver and read by the weatherstation plugin.
Make sure the read/write rights on the file are correct.
I have added the files you need for the upload, one php file and one template file.
Hope this will help you.
My wordpress site is www.waarstasjon-noardburgum.nl
MBrealtimeGet.zip
(833 Bytes) Downloaded 228 times
