Export Data in" minutes" gives no values. **solved**
ConligWX
Post by ConligWX »
Hi there.
could someone try to export data for me in a Nano SD or a Pro?
goto history tab,
select working sensor. (say th0temp as that has a value all the time)
select year, month, and a day that has data in it.
now goto Export Data. select template: either Cumulus, standard iso or standard imp template.
now export the day in minutes and the Export hour in minutes.
now goto your \\data\exports share and open the two text files.
when I do the exports on my Nano, the date/time are there but no data value exists. if I export in hours I have data.
day in hours:
# date, time, temperature[C], humidity[%], dew point[C], sealevel pressure[hPa], avg wind speed[m/s], gust speed[m/s], winddir, rainfall00
2020-02-04,00:00,3.0,91,1.6,1010.9,2.7,8.9,262,0.2
2020-02-04,01:00,3.3,86,1.2,1011.2,2.8,9.8,270,0.2
2020-02-04,02:00,2.8,90,1.3,1012.5,1.7,10.7,275,0.8
2020-02-04,03:00,3.3,89,1.6,1013.3,1.9,9.8,274,0.0
2020-02-04,04:00,4.0,86,1.8,1014.3,2.2,10.3,279,0.0
2020-02-04,05:00,4.7,83,2.0,1015.5,2.2,8.5,279,0.0
2020-02-04,06:00,5.7,83,3.0,1017.3,2.4,8.5,294,0.0
2020-02-04,07:00,6.1,87,4.1,1018.8,3.5,10.3,292,0.0
2020-02-04,08:00,6.7,86,4.5,1020.4,4.1,12.5,298,0.0
2020-02-04,09:00,7.5,83,4.8,1022.0,4.4,10.3,299,0.0
2020-02-04,10:00,7.9,79,4.5,1023.0,4.8,12.5,305,0.0
2020-02-04,11:00,8.0,78,4.4,1026.3,1.7,8.5,300,0.0
2020-02-04,12:00,8.2,78,4.6,1027.7,2.7,10.3,301,0.0
2020-02-04,13:00,8.7,76,4.6,1028.8,2.8,9.4,308,0.0
2020-02-04,14:00,9.1,71,4.1,1029.8,1.6,6.7,315,0.0
2020-02-04,15:00,8.6,75,4.5,1030.8,0.6,4.5,321,0.0
2020-02-04,16:00,7.9,79,4.6,1031.6,0.2,3.6,313,0.0
2020-02-04,17:00,7.4,83,4.6,1032.7,0.1,3.1,312,0.0
2020-02-04,18:00,6.4,84,4.0,1033.2,0.5,4.0,297,0.0
2020-02-04,19:00,6.2,83,3.5,1033.9,0.6,3.6,291,0.0
2020-02-04,20:00,5.5,84,3.0,1034.5,0.3,2.7,267,0.0
2020-02-04,21:00,5.0,85,2.7,1035.0,0.3,3.1,254,0.0
2020-02-04,22:00,4.3,86,2.3,1035.4,0.5,3.1,270,0.0
2020-02-04,23:00,4.3,86,2.2,1035.8,0.4,2.7,275,0.0
Day in mins
2020-02-04,00:00,,,,,,,,
2020-02-04,00:01,,,,,,,,
2020-02-04,00:02,,,,,,,,
2020-02-04,00:03,,,,,,,,
2020-02-04,00:04,,,,,,,,
2020-02-04,00:05,,,,,,,,
2020-02-04,00:06,,,,,,,,
2020-02-04,00:07,,,,,,,,
2020-02-04,00:08,,,,,,,,
2020-02-04,00:09,,,,,,,,
2020-02-04,00:10,,,,,,,,
2020-02-04,00:11,,,,,,,,
2020-02-04,00:12,,,,,,,,
2020-02-04,00:13,,,,,,,,
2020-02-04,00:14,,,,,,,,
Re: Export Data in" minutes" gives no values.
So would this be somehow a different export to the Service export?
I export 1 minute data for every (previous) day just after midnight for both MBPro's and NAnoSD's, output is as expected.
ConligWX
Post by ConligWX »
I havent tried that way as yet, just the way I tried doesn't seem to work, though the option in minutes is there.
When you do a power cycle, all per minute data is lost because it is just hold in a RAM database.
