Error messages in Meteobridge PRO log; uploading to weather networks seems to stop
JPB
Post by JPB »
I include them below. Note the 'database is locked' errors... Thanks for any help with this. Running the latest firmware from the site....
logger (31.07.2020 23:37:23): verbose off
logger (31.07.2020 23:37:23): output raw (8 bytes)
logger (31.07.2020 23:37:23): output raw (10 bytes)
logger (31.07.2020 23:37:23): filter on
logger (31.07.2020 23:37:23): rx threshold set to -80db
logger (31.07.2020 23:37:23): listening to transmitter 1 2
logger (31.07.2020 23:37:23): bandwidth narrow
logger (31.07.2020 23:37:23): chip authentication ok: 14
logger (31.07.2020 23:37:23): frequency band 915MHz (US)
logger (31.07.2020 23:37:24): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.07.2020 23:37:24): services paused.
logger (31.07.2020 23:39:19): give up waiting for sensors after 120 secs.
logger (31.07.2020 23:39:19): services activated.
logger (31.07.2020 23:39:28): DB cannot prepare select on rain0total_day (after 100 tries in 9144ms): database is locked (5)
logger (31.07.2020 23:39:28): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < find_persist < is_cumul < align_ts < get_timedata_pro < find_persist < get_timedata ...
logger (31.07.2020 23:39:28): disconnect station 0 (Meteostick Vantage): exit
logger (31.07.2020 23:39:28): disconnect station 9 (System Data): exit
logger (31.07.2020 23:39:30): data logger stopped.
logger (31.07.2020 23:39:30): databases disconnected.
logger (31.07.2020 23:39:30): databases connected. Update interval 3600 seconds.
logger (31.07.2020 23:39:30): data logger (version 5.1d, build 13617) started.
logger (31.07.2020 23:39:33): connect station 0 (Meteostick Vantage via USB serial).
logger (31.07.2020 23:39:33): connect station 9 (System Data via Plug-in).
logger (31.07.2020 23:39:34): transmitter 1 registered as ISS
logger (31.07.2020 23:39:34): transmitter 2 registered as Wind
logger (31.07.2020 23:39:34): Meteostick Version 2.5.1
logger (31.07.2020 23:39:34): debug off
logger (31.07.2020 23:39:34): verbose off
logger (31.07.2020 23:39:34): output raw (8 bytes)
logger (31.07.2020 23:39:34): output raw (10 bytes)
logger (31.07.2020 23:39:34): filter on
logger (31.07.2020 23:39:34): rx threshold set to -80db
logger (31.07.2020 23:39:34): listening to transmitter 1 2
logger (31.07.2020 23:39:34): bandwidth narrow
logger (31.07.2020 23:39:35): chip authentication ok: 14
logger (31.07.2020 23:39:35): frequency band 915MHz (US)
logger (31.07.2020 23:39:36): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.07.2020 23:39:36): services paused.
logger (31.07.2020 23:41:32): wind0 data incomplete (missing outdoor temp for windchill)
logger (31.07.2020 23:41:33): give up waiting for sensors after 120 secs.
logger (31.07.2020 23:41:33): services activated.
logger (31.07.2020 23:41:38): wind0 data incomplete (missing outdoor temp for windchill)
logger (31.07.2020 23:45:00): message above repeats 51 times.
logger (31.07.2020 23:45:02): wind1 data incomplete (missing outdoor temp for windchill)
logger (31.07.2020 23:45:02): wind0 data incomplete (missing outdoor temp for windchill)
logger (31.07.2020 23:45:07): wind1 data incomplete (missing outdoor temp for windchill)
logger (31.07.2020 23:45:17): DB cannot prepare select on rain0total_day (after 100 tries in 9130ms): database is locked (5)
logger (31.07.2020 23:45:17): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byvariable < is_invalid < find_persist < get_persist_byname < get_persist_byvariable < is_invalid...
logger (31.07.2020 23:45:17): disconnect station 0 (Meteostick Vantage): exit
logger (31.07.2020 23:45:17): disconnect station 9 (System Data): exit
logger (31.07.2020 23:45:19): data logger stopped.
logger (31.07.2020 23:45:19): databases disconnected.
logger (31.07.2020 23:45:19): databases connected. Update interval 3600 seconds.
logger (31.07.2020 23:45:19): data logger (version 5.1d, build 13617) started.
logger (31.07.2020 23:45:21): connect station 0 (Meteostick Vantage via USB serial).
logger (31.07.2020 23:45:21): connect station 9 (System Data via Plug-in).
logger (31.07.2020 23:45:23): transmitter 1 registered as ISS
logger (31.07.2020 23:45:23): transmitter 2 registered as Wind
logger (31.07.2020 23:45:23): Meteostick Version 2.5.1
logger (31.07.2020 23:45:23): debug off
logger (31.07.2020 23:45:23): verbose off
logger (31.07.2020 23:45:23): output raw (8 bytes)
logger (31.07.2020 23:45:23): output raw (10 bytes)
logger (31.07.2020 23:45:23): filter on
logger (31.07.2020 23:45:23): rx threshold set to -80db
logger (31.07.2020 23:45:23): listening to transmitter 1 2
logger (31.07.2020 23:45:23): bandwidth narrow
logger (31.07.2020 23:45:23): chip authentication ok: 14
logger (31.07.2020 23:45:23): frequency band 915MHz (US)
logger (31.07.2020 23:45:24): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.07.2020 23:45:24): services paused.
logger (31.07.2020 23:47:21): give up waiting for sensors after 120 secs.
logger (31.07.2020 23:47:21): services activated.
logger (31.07.2020 23:47:23): wind1 data incomplete (missing outdoor temp for windchill)
logger (31.07.2020 23:47:24): wind0 data incomplete (missing outdoor temp for windchill)
logger (31.07.2020 23:47:35): DB cannot prepare select on rain0total_day (after 100 tries in 9343ms): database is locked (5)
logger (31.07.2020 23:47:44): DB cannot prepare select on rain0total_day (after 100 tries in 9240ms): database is locked (5)
logger (31.07.2020 23:47:44): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < find_persist < get_persist_byname < get_persist_byname_map < find_persist < get_pers...
logger (31.07.2020 23:47:45): disconnect station 0 (Meteostick Vantage): exit
logger (31.07.2020 23:47:45): disconnect station 9 (System Data): exit
logger (31.07.2020 23:47:46): data logger stopped.
logger (31.07.2020 23:47:46): databases disconnected.
logger (31.07.2020 23:47:46): databases connected. Update interval 3600 seconds.
logger (31.07.2020 23:47:47): data logger (version 5.1d, build 13617) started.
logger (31.07.2020 23:47:48): connect station 0 (Meteostick Vantage via USB serial).
logger (31.07.2020 23:47:48): connect station 9 (System Data via Plug-in).
logger (31.07.2020 23:47:50): transmitter 1 registered as ISS
logger (31.07.2020 23:47:50): transmitter 2 registered as Wind
logger (31.07.2020 23:47:50): Meteostick Version 2.5.1
logger (31.07.2020 23:47:50): debug off
logger (31.07.2020 23:47:50): verbose off
logger (31.07.2020 23:47:50): output raw (8 bytes)
logger (31.07.2020 23:47:50): output raw (10 bytes)
logger (31.07.2020 23:47:50): filter on
logger (31.07.2020 23:47:50): rx threshold set to -80db
logger (31.07.2020 23:47:50): listening to transmitter 1 2
logger (31.07.2020 23:47:50): bandwidth narrow
logger (31.07.2020 23:47:51): chip authentication ok: 14
logger (31.07.2020 23:47:51): frequency band 915MHz (US)
logger (31.07.2020 23:47:52): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.07.2020 23:47:52): services paused.
logger (31.07.2020 23:49:49): give up waiting for sensors after 120 secs.
logger (31.07.2020 23:49:49): services activated.
logger (31.07.2020 23:50:01): DB cannot prepare select on rain0total_day (after 100 tries in 9160ms): database is locked (5)
logger (31.07.2020 23:50:01): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < find_persist < is_cumul < align_ts < get_timedata_pro < find_persist < get_timedata ...
logger (31.07.2020 23:50:01): disconnect station 0 (Meteostick Vantage): exit
logger (31.07.2020 23:50:01): disconnect station 9 (System Data): exit
logger (31.07.2020 23:50:03): data logger stopped.
logger (31.07.2020 23:50:03): databases disconnected.
logger (31.07.2020 23:50:03): databases connected. Update interval 3600 seconds.
logger (31.07.2020 23:50:03): data logger (version 5.1d, build 13617) started.
logger (31.07.2020 23:50:05): connect station 0 (Meteostick Vantage via USB serial).
logger (31.07.2020 23:50:05): connect station 9 (System Data via Plug-in).
logger (31.07.2020 23:50:07): transmitter 1 registered as ISS
logger (31.07.2020 23:50:07): transmitter 2 registered as Wind
logger (31.07.2020 23:50:07): Meteostick Version 2.5.1
logger (31.07.2020 23:50:07): debug off
logger (31.07.2020 23:50:07): verbose off
logger (31.07.2020 23:50:07): output raw (8 bytes)
logger (31.07.2020 23:50:07): output raw (10 bytes)
logger (31.07.2020 23:50:07): filter on
logger (31.07.2020 23:50:07): rx threshold set to -80db
logger (31.07.2020 23:50:07): listening to transmitter 1 2
logger (31.07.2020 23:50:07): bandwidth narrow
logger (31.07.2020 23:50:07): chip authentication ok: 14
logger (31.07.2020 23:50:07): frequency band 915MHz (US)
logger (31.07.2020 23:50:08): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.07.2020 23:50:08): services paused.
logger (31.07.2020 23:52:05): give up waiting for sensors after 120 secs.
logger (31.07.2020 23:52:05): services activated.
logger (31.07.2020 23:52:17): DB cannot prepare select on rain0total_day (after 100 tries in 9144ms): database is locked (5)
logger (31.07.2020 23:52:26): DB cannot prepare select on rain0total_day (after 100 tries in 9122ms): database is locked (5)
logger (31.07.2020 23:52:26): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < find_persist < get_persist_byname < get_persist_byname_map < find_persist < get_pers...
logger (31.07.2020 23:52:26): disconnect station 0 (Meteostick Vantage): exit
logger (31.07.2020 23:52:26): disconnect station 9 (System Data): exit
logger (31.07.2020 23:52:28): data logger stopped.
logger (31.07.2020 23:52:28): databases disconnected.
logger (31.07.2020 23:52:28): databases connected. Update interval 3600 seconds.
logger (31.07.2020 23:52:28): data logger (version 5.1d, build 13617) started.
logger (31.07.2020 23:52:30): connect station 0 (Meteostick Vantage via USB serial).
logger (31.07.2020 23:52:30): connect station 9 (System Data via Plug-in).
logger (31.07.2020 23:52:32): transmitter 1 registered as ISS
logger (31.07.2020 23:52:32): transmitter 2 registered as Wind
logger (31.07.2020 23:52:32): Meteostick Version 2.5.1
logger (31.07.2020 23:52:32): debug off
logger (31.07.2020 23:52:32): verbose off
logger (31.07.2020 23:52:32): output raw (8 bytes)
logger (31.07.2020 23:52:32): output raw (10 bytes)
logger (31.07.2020 23:52:32): filter on
logger (31.07.2020 23:52:32): rx threshold set to -80db
logger (31.07.2020 23:52:32): listening to transmitter 1 2
logger (31.07.2020 23:52:32): bandwidth narrow
logger (31.07.2020 23:52:32): chip authentication ok: 14
logger (31.07.2020 23:52:32): frequency band 915MHz (US)
logger (31.07.2020 23:52:33): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.07.2020 23:52:33): services paused.
logger (31.07.2020 23:54:30): give up waiting for sensors after 120 secs.
logger (31.07.2020 23:54:30): services activated.
logger (31.07.2020 23:54:35): wind0 data incomplete (missing outdoor temp for windchill)
logger (31.07.2020 23:58:05): message above repeats 35 times.
logger (31.07.2020 23:58:06): wind1 data incomplete (missing outdoor temp for windchill)
logger (31.07.2020 23:58:07): wind0 data incomplete (missing outdoor temp for windchill)
logger (31.07.2020 23:58:10): message above repeats 1 time.
logger (31.07.2020 23:58:20): DB cannot prepare select on rain0total_day (after 100 tries in 9109ms): database is locked (5)
logger (31.07.2020 23:58:20): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < find_persist < is_cumul < align_ts < get_timedata_pro < find_persist < get_timedata ...
logger (31.07.2020 23:58:20): disconnect station 0 (Meteostick Vantage): exit
logger (31.07.2020 23:58:21): disconnect station 9 (System Data): exit
logger (31.07.2020 23:58:24): data logger stopped.
logger (31.07.2020 23:58:24): databases disconnected.
logger (31.07.2020 23:58:24): databases connected. Update interval 3600 seconds.
logger (31.07.2020 23:58:24): data logger (version 5.1d, build 13617) started.
logger (31.07.2020 23:58:26): connect station 0 (Meteostick Vantage via USB serial).
logger (31.07.2020 23:58:26): connect station 9 (System Data via Plug-in).
logger (31.07.2020 23:58:28): transmitter 1 registered as ISS
logger (31.07.2020 23:58:28): transmitter 2 registered as Wind
logger (31.07.2020 23:58:28): Meteostick Version 2.5.1
logger (31.07.2020 23:58:28): debug off
logger (31.07.2020 23:58:28): verbose off
logger (31.07.2020 23:58:28): output raw (8 bytes)
logger (31.07.2020 23:58:28): output raw (10 bytes)
logger (31.07.2020 23:58:28): filter on
logger (31.07.2020 23:58:28): rx threshold set to -80db
logger (31.07.2020 23:58:28): listening to transmitter 1 2
logger (31.07.2020 23:58:28): bandwidth narrow
logger (31.07.2020 23:58:28): chip authentication ok: 14
logger (31.07.2020 23:58:28): frequency band 915MHz (US)
logger (31.07.2020 23:58:29): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.07.2020 23:58:29): services paused.
logger (01.08.2020 00:00:25): give up waiting for sensors after 120 secs.
logger (01.08.2020 00:00:25): services activated.
logger (01.08.2020 00:00:34): DB cannot prepare select on rain0total_day (after 100 tries in 9141ms): database is locked (5)
logger (01.08.2020 00:00:44): DB cannot prepare select on rain0total_day (after 100 tries in 9183ms): database is locked (5)
logger (01.08.2020 00:00:44): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < find_persist < get_persist_byname < get_persist_byname_map < find_persist < get_pers...
logger (01.08.2020 00:00:44): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:00:44): disconnect station 9 (System Data): exit
logger (01.08.2020 00:00:45): data logger stopped.
logger (01.08.2020 00:00:45): databases disconnected.
logger (01.08.2020 00:00:45): databases connected. Update interval 3600 seconds.
logger (01.08.2020 00:00:45): data logger (version 5.1d, build 13617) started.
logger (01.08.2020 00:00:47): connect station 0 (Meteostick Vantage via USB serial).
logger (01.08.2020 00:00:47): connect station 9 (System Data via Plug-in).
logger (01.08.2020 00:00:49): transmitter 1 registered as ISS
logger (01.08.2020 00:00:49): transmitter 2 registered as Wind
logger (01.08.2020 00:00:49): Meteostick Version 2.5.1
logger (01.08.2020 00:00:49): debug off
logger (01.08.2020 00:00:49): verbose off
logger (01.08.2020 00:00:49): output raw (8 bytes)
logger (01.08.2020 00:00:49): output raw (10 bytes)
logger (01.08.2020 00:00:49): filter on
logger (01.08.2020 00:00:49): rx threshold set to -80db
logger (01.08.2020 00:00:49): listening to transmitter 1 2
logger (01.08.2020 00:00:49): bandwidth narrow
logger (01.08.2020 00:00:50): chip authentication ok: 14
logger (01.08.2020 00:00:50): frequency band 915MHz (US)
logger (01.08.2020 00:00:51): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (01.08.2020 00:00:51): services paused.
logger (01.08.2020 00:02:46): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:02:48): give up waiting for sensors after 120 secs.
logger (01.08.2020 00:02:48): services activated.
logger (01.08.2020 00:02:57): DB cannot prepare select on rain0total_day (after 100 tries in 9120ms): database is locked (5)
logger (01.08.2020 00:03:07): DB cannot prepare select on rain0total_day (after 100 tries in 9257ms): database is locked (5)
logger (01.08.2020 00:03:07): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < find_persist < get_persist_byname < get_persist_byname_map < find_persist < get_pers...
logger (01.08.2020 00:03:07): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:03:07): disconnect station 9 (System Data): exit
logger (01.08.2020 00:03:08): data logger stopped.
logger (01.08.2020 00:03:08): databases disconnected.
logger (01.08.2020 00:03:09): databases connected. Update interval 3600 seconds.
logger (01.08.2020 00:03:09): data logger (version 5.1d, build 13617) started.
logger (01.08.2020 00:03:11): connect station 0 (Meteostick Vantage via USB serial).
logger (01.08.2020 00:03:11): connect station 9 (System Data via Plug-in).
logger (01.08.2020 00:03:12): transmitter 1 registered as ISS
logger (01.08.2020 00:03:12): transmitter 2 registered as Wind
logger (01.08.2020 00:03:12): Meteostick Version 2.5.1
logger (01.08.2020 00:03:12): debug off
logger (01.08.2020 00:03:12): verbose off
logger (01.08.2020 00:03:12): output raw (8 bytes)
logger (01.08.2020 00:03:12): output raw (10 bytes)
logger (01.08.2020 00:03:12): filter on
logger (01.08.2020 00:03:12): rx threshold set to -80db
logger (01.08.2020 00:03:12): listening to transmitter 1 2
logger (01.08.2020 00:03:12): bandwidth narrow
logger (01.08.2020 00:03:13): chip authentication ok: 14
logger (01.08.2020 00:03:13): frequency band 915MHz (US)
logger (01.08.2020 00:03:14): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (01.08.2020 00:03:14): services paused.
logger (01.08.2020 00:05:11): give up waiting for sensors after 120 secs.
logger (01.08.2020 00:05:11): services activated.
logger (01.08.2020 00:05:15): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:06:44): message above repeats 17 times.
logger (01.08.2020 00:06:46): wind1 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:06:49): message above repeats 1 time.
logger (01.08.2020 00:06:50): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:07:03): DB cannot prepare select on rain0total_day (after 100 tries in 9129ms): database is locked (5)
logger (01.08.2020 00:07:13): DB cannot prepare select on rain0total_day (after 100 tries in 9168ms): database is locked (5)
logger (01.08.2020 00:07:13): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byvariable < is_invalid < find_persist < get_persist_byname < get_persist_byvariable < is_invalid...
logger (01.08.2020 00:07:13): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:07:13): disconnect station 9 (System Data): exit
logger (01.08.2020 00:07:14): data logger stopped.
logger (01.08.2020 00:07:14): databases disconnected.
logger (01.08.2020 00:07:14): databases connected. Update interval 3600 seconds.
logger (01.08.2020 00:07:14): data logger (version 5.1d, build 13617) started.
logger (01.08.2020 00:07:16): connect station 0 (Meteostick Vantage via USB serial).
logger (01.08.2020 00:07:16): connect station 9 (System Data via Plug-in).
logger (01.08.2020 00:07:18): transmitter 1 registered as ISS
logger (01.08.2020 00:07:18): transmitter 2 registered as Wind
logger (01.08.2020 00:07:18): Meteostick Version 2.5.1
logger (01.08.2020 00:07:18): debug off
logger (01.08.2020 00:07:18): verbose off
logger (01.08.2020 00:07:18): output raw (8 bytes)
logger (01.08.2020 00:07:18): output raw (10 bytes)
logger (01.08.2020 00:07:18): filter on
logger (01.08.2020 00:07:18): rx threshold set to -80db
logger (01.08.2020 00:07:18): listening to transmitter 1 2
logger (01.08.2020 00:07:18): bandwidth narrow
logger (01.08.2020 00:07:19): chip authentication ok: 14
logger (01.08.2020 00:07:19): frequency band 915MHz (US)
logger (01.08.2020 00:07:20): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (01.08.2020 00:07:20): services paused.
logger (01.08.2020 00:09:17): give up waiting for sensors after 120 secs.
logger (01.08.2020 00:09:17): services activated.
logger (01.08.2020 00:09:17): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:09:19): message above repeats 1 time.
logger (01.08.2020 00:09:20): wind1 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:09:32): DB cannot prepare select on rain0total_day (after 100 tries in 9291ms): database is locked (5)
logger (01.08.2020 00:09:32): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byvariable < is_invalid < find_persist < get_persist_byname < get_persist_byvariable < is_invalid...
logger (01.08.2020 00:09:32): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:09:32): disconnect station 9 (System Data): exit
logger (01.08.2020 00:09:34): data logger stopped.
logger (01.08.2020 00:09:34): databases disconnected.
logger (01.08.2020 00:09:34): databases connected. Update interval 3600 seconds.
logger (01.08.2020 00:09:34): data logger (version 5.1d, build 13617) started.
logger (01.08.2020 00:09:36): connect station 0 (Meteostick Vantage via USB serial).
logger (01.08.2020 00:09:36): connect station 9 (System Data via Plug-in).
logger (01.08.2020 00:09:38): transmitter 1 registered as ISS
logger (01.08.2020 00:09:38): transmitter 2 registered as Wind
logger (01.08.2020 00:09:38): Meteostick Version 2.5.1
logger (01.08.2020 00:09:38): debug off
logger (01.08.2020 00:09:38): verbose off
logger (01.08.2020 00:09:38): output raw (8 bytes)
logger (01.08.2020 00:09:38): output raw (10 bytes)
logger (01.08.2020 00:09:38): filter on
logger (01.08.2020 00:09:38): rx threshold set to -80db
logger (01.08.2020 00:09:38): listening to transmitter 1 2
logger (01.08.2020 00:09:38): bandwidth narrow
logger (01.08.2020 00:09:38): chip authentication ok: 14
logger (01.08.2020 00:09:38): frequency band 915MHz (US)
logger (01.08.2020 00:09:39): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (01.08.2020 00:09:39): services paused.
logger (01.08.2020 00:11:36): give up waiting for sensors after 120 secs.
logger (01.08.2020 00:11:36): services activated.
logger (01.08.2020 00:11:49): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:13:02): message above repeats 13 times.
logger (01.08.2020 00:13:18): wind1 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:13:21): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:13:46): DB cannot prepare select on rain0total_day (after 100 tries in 9214ms): database is locked (5)
logger (01.08.2020 00:13:55): DB cannot prepare select on rain0total_day (after 100 tries in 9206ms): database is locked (5)
logger (01.08.2020 00:13:55): child process received termination signal (11) in functions: termination_handler < align_ts < get_timedata_pro < find_persist < get_timedata < is_same_year < sync_data < find_persist < get_special_byname < get_persist_byvariable < valconvd < is_time_p < is_invalid < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname ...
logger (01.08.2020 00:13:55): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:13:55): disconnect station 9 (System Data): exit
logger (01.08.2020 00:13:57): data logger stopped.
logger (01.08.2020 00:24:06): child process received timeout signal (14).
logger (01.08.2020 00:24:08): data logger stopped.
logger (01.08.2020 00:24:08): databases disconnected.
logger (01.08.2020 00:24:08): databases connected. Update interval 3600 seconds.
logger (01.08.2020 00:24:08): data logger (version 5.1d, build 13617) started.
logger (01.08.2020 00:24:10): connect station 0 (Meteostick Vantage via USB serial).
logger (01.08.2020 00:24:10): connect station 9 (System Data via Plug-in).
logger (01.08.2020 00:24:13): transmitter 1 registered as ISS
logger (01.08.2020 00:24:13): transmitter 2 registered as Wind
logger (01.08.2020 00:24:13): Meteostick Version 2.5.1
logger (01.08.2020 00:24:13): debug off
logger (01.08.2020 00:24:13): verbose off
logger (01.08.2020 00:24:13): output raw (8 bytes)
logger (01.08.2020 00:24:13): output raw (10 bytes)
logger (01.08.2020 00:24:13): filter on
logger (01.08.2020 00:24:13): rx threshold set to -80db
logger (01.08.2020 00:24:13): listening to transmitter 1 2
logger (01.08.2020 00:24:13): bandwidth narrow
logger (01.08.2020 00:24:13): chip authentication ok: 14
logger (01.08.2020 00:24:14): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (01.08.2020 00:24:14): services paused.
logger (01.08.2020 00:24:14): frequency band 915MHz (US)
logger (01.08.2020 00:26:10): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:26:11): give up waiting for sensors after 120 secs.
logger (01.08.2020 00:26:11): services activated.
logger (01.08.2020 00:26:26): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:28:29): message above repeats 23 times.
logger (01.08.2020 00:28:33): wind1 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:28:34): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:28:45): DB cannot prepare select on rain0total_day (after 100 tries in 9197ms): database is locked (5)
logger (01.08.2020 00:28:54): DB cannot prepare select on rain0total_day (after 100 tries in 9189ms): database is locked (5)
logger (01.08.2020 00:28:54): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byvariable < is_invalid < find_persist < get_persist_byname < get_persist_byvariable < is_invalid...
logger (01.08.2020 00:28:54): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:28:55): disconnect station 9 (System Data): exit
logger (01.08.2020 00:28:56): data logger stopped.
logger (01.08.2020 00:28:56): databases disconnected.
logger (01.08.2020 00:28:57): databases connected. Update interval 3600 seconds.
logger (01.08.2020 00:28:57): data logger (version 5.1d, build 13617) started.
logger (01.08.2020 00:28:59): connect station 0 (Meteostick Vantage via USB serial).
logger (01.08.2020 00:28:59): connect station 9 (System Data via Plug-in).
logger (01.08.2020 00:29:01): transmitter 1 registered as ISS
logger (01.08.2020 00:29:01): transmitter 2 registered as Wind
logger (01.08.2020 00:29:01): Meteostick Version 2.5.1
logger (01.08.2020 00:29:01): debug off
logger (01.08.2020 00:29:01): verbose off
logger (01.08.2020 00:29:01): output raw (8 bytes)
logger (01.08.2020 00:29:01): output raw (10 bytes)
logger (01.08.2020 00:29:01): filter on
logger (01.08.2020 00:29:01): rx threshold set to -80db
logger (01.08.2020 00:29:01): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (01.08.2020 00:29:01): services paused.
logger (01.08.2020 00:29:01): listening to transmitter 1 2
logger (01.08.2020 00:29:01): bandwidth narrow
logger (01.08.2020 00:29:01): chip authentication ok: 14
logger (01.08.2020 00:29:01): frequency band 915MHz (US)
logger (01.08.2020 00:30:59): give up waiting for sensors after 120 secs.
logger (01.08.2020 00:30:59): services activated.
logger (01.08.2020 00:31:07): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:35:06): message above repeats 47 times.
logger (01.08.2020 00:35:08): wind1 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:35:11): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:35:13): wind1 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:35:25): DB cannot prepare select on rain0total_day (after 100 tries in 9202ms): database is locked (5)
logger (01.08.2020 00:35:25): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < is_cumul < align_ts < get_timedata_pro < find_persist < get_timedata < is_same_year ...
logger (01.08.2020 00:35:25): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:35:25): disconnect station 9 (System Data): exit
logger (01.08.2020 00:35:27): data logger stopped.
logger (01.08.2020 00:35:27): databases disconnected.
logger (01.08.2020 00:35:27): databases connected. Update interval 3600 seconds.
logger (01.08.2020 00:35:27): data logger (version 5.1d, build 13617) started.
logger (01.08.2020 00:35:29): connect station 0 (Meteostick Vantage via USB serial).
logger (01.08.2020 00:35:29): connect station 9 (System Data via Plug-in).
logger (01.08.2020 00:35:31): transmitter 1 registered as ISS
logger (01.08.2020 00:35:31): transmitter 2 registered as Wind
logger (01.08.2020 00:35:31): Meteostick Version 2.5.1
logger (01.08.2020 00:35:31): debug off
logger (01.08.2020 00:35:31): verbose off
logger (01.08.2020 00:35:31): output raw (8 bytes)
logger (01.08.2020 00:35:31): output raw (10 bytes)
logger (01.08.2020 00:35:31): filter on
logger (01.08.2020 00:35:31): rx threshold set to -80db
logger (01.08.2020 00:35:31): listening to transmitter 1 2
logger (01.08.2020 00:35:31): bandwidth narrow
logger (01.08.2020 00:35:32): chip authentication ok: 14
logger (01.08.2020 00:35:32): frequency band 915MHz (US)
logger (01.08.2020 00:35:33): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (01.08.2020 00:35:33): services paused.
logger (01.08.2020 00:37:29): give up waiting for sensors after 120 secs.
logger (01.08.2020 00:37:29): services activated.
logger (01.08.2020 00:37:39): DB cannot prepare select on rain0total_day (after 100 tries in 9135ms): database is locked (5)
logger (01.08.2020 00:37:48): DB cannot prepare select on rain0total_day (after 100 tries in 9160ms): database is locked (5)
logger (01.08.2020 00:37:48): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < find_persist < get_persist_byname < get_persist_byname_map < find_persist < get_pers...
logger (01.08.2020 00:37:48): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:37:48): disconnect station 9 (System Data): exit
logger (01.08.2020 00:37:49): data logger stopped.
logger (01.08.2020 00:37:49): databases disconnected.
logger (01.08.2020 00:37:49): databases connected. Update interval 3600 seconds.
logger (01.08.2020 00:37:49): data logger (version 5.1d, build 13617) started.
logger (01.08.2020 00:37:51): connect station 0 (Meteostick Vantage via USB serial).
logger (01.08.2020 00:37:51): connect station 9 (System Data via Plug-in).
logger (01.08.2020 00:37:53): transmitter 1 registered as ISS
logger (01.08.2020 00:37:53): transmitter 2 registered as Wind
logger (01.08.2020 00:37:53): Meteostick Version 2.5.1
logger (01.08.2020 00:37:53): debug off
logger (01.08.2020 00:37:53): verbose off
logger (01.08.2020 00:37:53): output raw (8 bytes)
logger (01.08.2020 00:37:53): output raw (10 bytes)
logger (01.08.2020 00:37:53): filter on
logger (01.08.2020 00:37:53): rx threshold set to -80db
logger (01.08.2020 00:37:53): listening to transmitter 1 2
logger (01.08.2020 00:37:53): bandwidth narrow
logger (01.08.2020 00:37:53): chip authentication ok: 14
logger (01.08.2020 00:37:53): frequency band 915MHz (US)
logger (01.08.2020 00:37:54): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (01.08.2020 00:37:54): services paused.
logger (01.08.2020 00:39:51): give up waiting for sensors after 120 secs.
logger (01.08.2020 00:39:51): services activated.
logger (01.08.2020 00:39:52): wind0 data incomplete (missing outdoor temp for windchill)
logger (01.08.2020 00:44:56): message above repeats 55 times.
logger (01.08.2020 00:45:10): DB cannot prepare select on thb0seapress_day (after 100 tries in 9131ms): database is locked (5)
logger (01.08.2020 00:45:10): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < awekas_minavgmax < find_persist < get_persist_byname < get_persist_byname_map < find...
logger (01.08.2020 00:45:10): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:45:10): disconnect station 9 (System Data): exit
logger (01.08.2020 00:45:12): data logger stopped.
logger (01.08.2020 00:45:12): databases disconnected.
logger (01.08.2020 00:45:12): databases connected. Update interval 3600 seconds.
logger (01.08.2020 00:45:12): data logger (version 5.1d, build 13617) started.
logger (01.08.2020 00:45:14): connect station 0 (Meteostick Vantage via USB serial).
logger (01.08.2020 00:45:14): connect station 9 (System Data via Plug-in).
logger (01.08.2020 00:45:16): transmitter 1 registered as ISS
logger (01.08.2020 00:45:16): transmitter 2 registered as Wind
logger (01.08.2020 00:45:16): Meteostick Version 2.5.1
logger (01.08.2020 00:45:16): debug off
logger (01.08.2020 00:45:16): verbose off
logger (01.08.2020 00:45:16): output raw (8 bytes)
logger (01.08.2020 00:45:16): output raw (10 bytes)
logger (01.08.2020 00:45:16): filter on
logger (01.08.2020 00:45:16): rx threshold set to -80db
logger (01.08.2020 00:45:16): listening to transmitter 1 2
logger (01.08.2020 00:45:16): bandwidth narrow
logger (01.08.2020 00:45:16): chip authentication ok: 14
logger (01.08.2020 00:45:16): frequency band 915MHz (US)
logger (01.08.2020 00:45:17): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (01.08.2020 00:45:17): services paused.
logger (01.08.2020 00:47:14): give up waiting for sensors after 120 secs.
logger (01.08.2020 00:47:14): services activated.
logger (01.08.2020 00:47:25): DB cannot prepare select on rain0total_day (after 100 tries in 9142ms): database is locked (5)
logger (01.08.2020 00:47:25): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < is_cumul < align_ts < get_timedata_pro < find_persist < get_timedata < is_same_year ...
logger (01.08.2020 00:47:25): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:47:25): disconnect station 9 (System Data): exit
logger (01.08.2020 00:47:26): data logger stopped.
logger (01.08.2020 00:47:26): databases disconnected.
logger (01.08.2020 00:47:26): databases connected. Update interval 3600 seconds.
logger (01.08.2020 00:47:26): data logger (version 5.1d, build 13617) started.
logger (01.08.2020 00:47:28): connect station 0 (Meteostick Vantage via USB serial).
logger (01.08.2020 00:47:28): connect station 9 (System Data via Plug-in).
logger (01.08.2020 00:47:30): transmitter 1 registered as ISS
logger (01.08.2020 00:47:30): transmitter 2 registered as Wind
logger (01.08.2020 00:47:30): Meteostick Version 2.5.1
logger (01.08.2020 00:47:30): debug off
logger (01.08.2020 00:47:30): verbose off
logger (01.08.2020 00:47:30): output raw (8 bytes)
logger (01.08.2020 00:47:30): output raw (10 bytes)
logger (01.08.2020 00:47:30): filter on
logger (01.08.2020 00:47:30): rx threshold set to -80db
logger (01.08.2020 00:47:30): listening to transmitter 1 2
logger (01.08.2020 00:47:30): bandwidth narrow
logger (01.08.2020 00:47:30): chip authentication ok: 14
logger (01.08.2020 00:47:30): frequency band 915MHz (US)
logger (01.08.2020 00:47:31): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (01.08.2020 00:47:31): services paused.
logger (01.08.2020 00:48:52): sensors are now providing data.
logger (01.08.2020 00:48:52): services started.
logger (01.08.2020 00:49:02): DB cannot prepare select on rain0total_day (after 100 tries in 9127ms): database is locked (5)
logger (01.08.2020 00:49:02): child process received termination signal (11) in functions: termination_handler < align_ts_day < align_ts < get_timedata_pro < get_numdays < make_ts_day < get_persist_pro < get_persist < is_same_year < sync_data < find_persist < get_persist_byname < get_persist_byname_map < is_cumul < align_ts < get_timedata_pro < find_persist < get_timedata < is_same_year ...
logger (01.08.2020 00:49:02): disconnect station 0 (Meteostick Vantage): exit
logger (01.08.2020 00:49:02): disconnect station 9 (System Data): exit
logger (01.08.2020 00:49:03): data logger stopped.
logger (01.08.2020 00:59:22): child process received timeout signal (14).
logger (01.08.2020 00:59:24): data logger stopped.
JPB
Re: Error messages in Meteobridge PRO log; uploading to weather networks seems to stop
Post by JPB »
Downgrading to 4.3 has, at least for the first 1.5 hours, resolved these issues for me. I'll see how long things stay stable.
JPB
Post by JPB »
Same problem has now been seen on release 4.3. Around 12:30 am, started getting all these errors. Later today, I am going to try a complete factory reset and see if that helps.
The root cause seems to be the database being locked.
Can you please post the complete "System" tab including inforation about used storage, etc?
