Display wind in Knots
Hoxton
Post by Hoxton »
Hi my unit currently displays wind speed in K/mh I would like to change it to Knots. So that the actual display on the unit is in knots.
Is there a way to do this?
I had a look on the wiki but couldn't find an answer there.
Re: Display wind in Knots
Hoxton wrote: Mon Aug 10, 2020 9:28 pm Hi my unit currently displays wind speed in K/mh I would like to change it to Knots. So that the actual display on the unit is in knots.
It is in the WiKi https://www.meteobridge.com/wiki/index.php/PRO_Display
Go to Loop on Weather Data ==> Second screen definition named "a1" starts with drawing a rounded box n the top labeled with "WIND"
Change the lines with windspeeds similar to the example "#string 50 30 [wind0wind-max5.1:--] m/s\n\"
In your case it is set to kmh, change that to kn
But it is along time ago when my MB-Pro died, so I can not check it myself.
Succes
Do you run the OLED display continuously or use the screen saver?
