GW5000/DP1500. and Davis RF togeter **solved**
ongenal
Post by ongenal »
My weather station is built with the Davis Vantage Pro 2 an a Meteobridge PRO receiver.
I recent bought a DP1500 to add (cheaper) a lighting sensor, and some additional temp soil sensors.
Is there a way to setup the Meteobrige Pro to collect the data from both gateways at the same time? As far as I can see, I can only activate one at a time.
Re: GW5000/DP1500. and Davis RF togeter
Currently Meteobridges do only support one station at a time.
Gyvate
Post by Gyvate »
The above statement by Boris might have changed with the new 14 Sep 2020, 13729 version which now allows multi-station usage.
admin wrote: Wed Aug 19, 2020 8:27 am Currently Meteobridges do only support one station at a time.
Yes, no longer true. Meteobridges can handle up to 5 weather stations in parallel from version 4.4 on.
