Have been running meteohub for many years and want to update my old pi b to a pi 3 b, so I bought a pi 3 b and downloaded the recommended image (5.0s). This boots to a command line login as expected. I can log in as root. The machine has acquired 192.168.20.16 as it's IP address from a hard wired ethernet connection, and for some reason has created 192.168.1.77 as a sub interface (quite why is beyond me - that can never work). Regardless the machine is not listening on port 80 on it's primary IP address. as evidenced by netstat :
root@meteohub-rpi:~# netstat -an
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:45068 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:5554 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:5555 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:5556 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:5557 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:5558 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:5559 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:5558 127.0.0.1:50978 TIME_WAIT
tcp 0 0 127.0.0.1:5558 127.0.0.1:50980 TIME_WAIT
tcp 0 208 192.168.20.16:22 192.168.10.227:53014 ESTABLISHED
tcp 0 0 127.0.0.1:5558 127.0.0.1:50976 TIME_WAIT
tcp6 0 0 :::445 :::* LISTEN
tcp6 0 0 :::7777 :::* LISTEN
tcp6 0 0 :::45190 :::* LISTEN
tcp6 0 0 :::139 :::* LISTEN
tcp6 0 0 :::111 :::* LISTEN
tcp6 0 0 :::80 :::* LISTEN
tcp6 0 0 :::22 :::* LISTEN
udp 0 0 0.0.0.0:958 0.0.0.0:*
udp 0 0 127.0.0.1:990 0.0.0.0:*
udp 0 0 0.0.0.0:35825 0.0.0.0:*
udp 0 0 0.0.0.0:68 0.0.0.0:*
udp 0 0 0.0.0.0:111 0.0.0.0:*
udp 0 0 192.168.1.77:123 0.0.0.0:*
udp 0 0 192.168.20.16:123 0.0.0.0:*
udp 0 0 127.0.0.1:123 0.0.0.0:*
udp 0 0 0.0.0.0:123 0.0.0.0:*
udp 0 0 192.168.1.255:137 0.0.0.0:*
udp 0 0 192.168.1.77:137 0.0.0.0:*
udp 0 0 192.168.20.255:137 0.0.0.0:*
udp 0 0 192.168.20.16:137 0.0.0.0:*
udp 0 0 0.0.0.0:137 0.0.0.0:*
udp 0 0 192.168.1.255:138 0.0.0.0:*
udp 0 0 192.168.1.77:138 0.0.0.0:*
udp 0 0 192.168.20.255:138 0.0.0.0:*
udp 0 0 192.168.20.16:138 0.0.0.0:*
udp 0 0 0.0.0.0:138 0.0.0.0:*
udp 0 0 0.0.0.0:57728 0.0.0.0:*
udp6 0 0 :::958 :::*
udp6 0 0 :::42058 :::*
udp6 0 0 :::111 :::*
udp6 0 0 fe80::ba27:ebff:fe7:123 :::*
udp6 0 0 ::1:123 :::*
udp6 0 0 :::123 :::*
udp6 0 0 :::44722 :::*
So I guess the question is . . . why ?
As expected I can ssh into the machine without issue, just no admin page being served.
Whay am I doing wrong and does any kind of setup guide exist ? . . . It used to be simple . . . not so any more.
TIA
Fd
