Thanks Galfert for your extensive answer at my question, appreciate that very much.
I forgot to mention that my console is a Vue but my station outside is Davis VP2 pro. I’ve earlier tried to find a possibility to make adjustments at the Vue console with the manual at hand, but the only thing a can choose is rain measured in inch or mm and as far as I tried nothing else. By the way, the console is a EU version, but as I said, I can choose for inches or mm (Netherlands all measuring is in mm).
The measurements “by hand” are with the rain gauche from Netatmo and a second one, semi pro, I find at Amazon, so no playing around with the toy stuff
. That’s when I noticed the Davis had a 10% disturbance with each comparison.
The tip you gave to make adjustments at the station itself for me it’s a tricky one. On regular basis I cleaned the unit from debris and the local spider population, but it happens very quick that the rain instrument inside get touched and the rain rate measured at that moment would be the end of the Netherlands
Maybe you have expertise with the VP2 and some tricks to clean and make adjustments without a reset on the Vue console? I’m not sure what type VP2 I’ve got, bought it in the Netherlands so I think a EU one.
Also I’ve find a easy way on the MB since Boris extended the way to make adjustments on various measurements at the MB and I heard what you mentioned about the differences between console and my website, so I’ll wait with that.
Again, many thanks for your tips and I hope, if you have one for the VP2, you keep me in mind.
