MB Pro stops transmitting data
BeBe
Post by BeBe »
Since 22-08-2020 at 00:32, the MB Pro stopped sending data. The second red light from above blinked when I discovered it hours later. After a reboot due to a power cut, everything worked normally again.
BeBe
BeBe
Re: MB Pro stops transmitting data
Post by BeBe »
Data registration and therefore also data transmission stopped again on September 10 at about 13:00 hour.
Two times in a few weeks. That is not normal.
What could be the cause of this?
After a restart due to a power cut, everything works again.
BeBe
Nobody can work on this until you post what messages section shows when this happens, buffer status on system tab, etc.
Do you have Meteoplug upload enabled?
