Template and export folders **solved**
Lespius
Post by Lespius »
Helle,
Silly question... I am just unable to access the templates and export folders.
I have tried http://192.xxx.0.11/data/templates --> answer is "No such file or directory"
What I want to do is write a template in order to export a csv or txt file to upload missing data in Meteotemplate. But I don't understand where are these templates and were is the export file generated and saved....
Many tanks!
Re: Template and export folders
Try \\192.xxx.0.11\data\
As Mattk indicates, it is available as a PC network share (SMB). You can access it with the string given by Mattk from your windows explorer.
Lespius
Re: Template and export folders **solved**
Post by Lespius »
Many thanks !!!
The missing piece was the windows explorer :D
