Meteobridge PRO spontaneously stops transmitting data
Posted: Sun Aug 23, 2020 7:49 pm
by c0by
I recently acquired a used Meteobridge Pro Red.
Unfortunately I have to notice, that in some intervals no more data is transferred.
In the log it says the following. Just like that during operation.
logger (23.08.2020 19:38:44): error while waiting for data from weather stations
logger (23.08.2020 19:38:44): disconnect station 0 (Meteostick Vantage): wrap-up
logger (23.08.2020 19:38:44): disconnect station 9 (System Data): wrap-up
logger (23.08.2020 19:38:45): databases disconnected.
logger (23.08.2020 19:38:45): data logger stopped.
logger (23.08.2020 19:38:45): databases connected. Update interval 3600 seconds.
logger (23.08.2020 19:38:45): data logger (version 5.1d, build 13640) started.
logger (23.08.2020 19:38:46): connect station 0 (Meteostick Vantage via USB serial).
logger (23.08.2020 19:38:46): connect station 9 (System Data via Plug-in).
logger (23.08.2020 19:38:48): transmitter 1 registered as ISS
logger (23.08.2020 19:38:48): Meteostick Version 2.5.2
logger (23.08.2020 19:38:48): debug off
logger (23.08.2020 19:38:48): verbose off
logger (23.08.2020 19:38:48): output raw (8 bytes)
logger (23.08.2020 19:38:48): output raw (10 bytes)
logger (23.08.2020 19:38:48): filter on
logger (23.08.2020 19:38:48): rx threshold set to -95db
logger (23.08.2020 19:38:48): listening to transmitter 1
logger (23.08.2020 19:38:48): bandwidth narrow
logger (23.08.2020 19:38:48): chip authentication ok: 14
logger (23.08.2020 19:38:48): frequency band 868MHz (EU)
logger (23.08.2020 19:38:49): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (23.08.2020 19:38:49): services paused.
logger (23.08.2020 19:40:46): give up waiting for sensors after 120 secs.
logger (23.08.2020 19:40:46): services activated.
SW-Version:	Meteobridge 4.4 (Aug 18 2020, build 13640), FW 1.4
2020-08-23 19_58_13-Window.png (10.63 KiB) Viewed 2232 times
logger (23.08.2020 20:13:17): error while waiting for data from weather stations
logger (23.08.2020 20:13:17): disconnect station 0 (Meteostick Vantage): wrap-up
Does anyone have any idea?
Re: Meteobridge PRO spontaneously stops transmitting data
Posted: Sun Aug 23, 2020 8:52 pm
by c0by
system (23.08.2020 20:51:02): stop of logging process initiated.
logger (23.08.2020 20:51:02): parent process received termination signal (15).
logger (23.08.2020 20:51:02): child process received termination signal (15).
logger (23.08.2020 20:51:02): disconnect station 0 (Meteostick Vantage): exit
logger (23.08.2020 20:51:02): disconnect station 9 (System Data): exit
logger (23.08.2020 20:51:03): data logger stopped.
logger (23.08.2020 20:51:03): databases disconnected.
logger (23.08.2020 20:51:03): parent process to be terminated.
system (23.08.2020 20:51:04): start of logging process initiated.
logger (23.08.2020 20:51:05): databases connected. Update interval 3600 seconds.
logger (23.08.2020 20:51:05): data logger (version 5.1d, build 13640) started.
logger (23.08.2020 20:51:06): connect station 0 (Meteostick Vantage via USB serial).
logger (23.08.2020 20:51:06): connect station 9 (System Data via Plug-in).
logger (23.08.2020 20:51:08): transmitter 1 registered as ISS
logger (23.08.2020 20:51:08): Meteostick Version 2.5.2
logger (23.08.2020 20:51:08): debug off
logger (23.08.2020 20:51:08): verbose off
logger (23.08.2020 20:51:08): output raw (8 bytes)
logger (23.08.2020 20:51:08): output raw (10 bytes)
logger (23.08.2020 20:51:08): filter on
logger (23.08.2020 20:51:08): rx threshold set to -95db
logger (23.08.2020 20:51:08): listening to transmitter 1
logger (23.08.2020 20:51:08): bandwidth narrow
logger (23.08.2020 20:51:08): chip authentication ok: 14
logger (23.08.2020 20:51:08): frequency band 868MHz (EU)
logger (23.08.2020 20:51:09): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (23.08.2020 20:51:09): services paused.
Posted: Sun Aug 23, 2020 10:45 pm
by Mattk
What is the distance from the ISS to the MBPro? It appears to not be receiving data from the ISS? You could try changing the RF Sens to -85 or -80db but if the distance is large then not much is going to fix reception?
Posted: Mon Aug 24, 2020 7:48 am
by c0by
The distance is about 60m with an signal strength of -60 / -80 dB. Same Issue with direct connection via console.
2020-08-24 18_04_46-Window.png (4.84 KiB) Viewed 2192 times
Posted: Wed Aug 26, 2020 10:58 am
Did changing RF sensitivity to -80db solve the issue (which to my experience would do)?
Posted: Wed Aug 26, 2020 1:18 pm
by c0by
Why -80db, could you explain please? I will test it.
Posted: Fri Sep 04, 2020 12:28 am
-95db might catch too much rf noise so that the receiver is "blinded".
