Something goes wrong with the latest update.
Will this problem be solved, Thank you in advance.
maximum number of translations reached (1200): /home/meteohub//Dutch.lang
As far as I have been able to test, the problem occurs on the meteobridge standard and the pro.
maximum number of translations. **solved**
- Senior Boarder
Sincerely,
Re: maximum number of translations
Just released an update fixing this. Please reboot and try again.
- Senior Boarder
Re: maximum number of translations. **solved**
May I thank you again very much Boris, the problem has been solved and the message is no longer visible.
Sincerely,
