Ver 4.4 rf signal not read correctly. **solved**
Tman
Post by Tman »
I'm afraid the problem with datalogger still exists. See the following log. (Vantage Pro 2 with console retransmitting)
 logger (14.09.2020 06:01:12): data logger (version 5.1d, build 13728) started.
logger (14.09.2020 06:01:15): connect station 0 (Meteostick Vantage via USB serial).
logger (14.09.2020 06:01:15): connect station 9 (System Data via Plug-in).
logger (14.09.2020 06:01:15): station 0 (Meteostick Vantage), transmitter 2 registered as ISS
logger (14.09.2020 06:01:15): station 0 (Meteostick Vantage), Meteostick Version 2.5.2
logger (14.09.2020 06:01:15): station 0 (Meteostick Vantage), debug off
logger (14.09.2020 06:01:15): station 0 (Meteostick Vantage), verbose off
logger (14.09.2020 06:01:15): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (14.09.2020 06:01:15): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (14.09.2020 06:01:15): station 0 (Meteostick Vantage), filter on
logger (14.09.2020 06:01:15): station 0 (Meteostick Vantage), rx threshold set to -85db
logger (14.09.2020 06:01:15): station 0 (Meteostick Vantage), listening to transmitter 2
logger (14.09.2020 06:01:15): station 0 (Meteostick Vantage), bandwidth narrow
logger (14.09.2020 06:01:16): station 0 (Meteostick Vantage), chip authentication ok: 14
logger (14.09.2020 06:01:16): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (14.09.2020 06:01:18): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.09.2020 06:01:18): services paused.
logger (14.09.2020 06:02:17): sensors are now providing data.
logger (14.09.2020 06:02:17): services started.
logger (14.09.2020 06:12:17): station 0 (Meteostick Vantage), restart meteostick (350 secs no valid rf signal)
export (14.09.2020 07:00:02): 0 lines of data written to file: SystemStatus-2020-month.txt
logger (14.09.2020 07:18:20): station 0 (Meteostick Vantage), restart meteostick (300 secs no valid rf signal)
-Timo
Re: Ver 4.4 rf signal not read correctly
"bandwidth narrow" in the log indicates that it is not in "via console" mode.
I just released a new version that should do. Please reboot.
Tman
Post by Tman »
Downloaded the latest firmware 4.4 / 14.9
Indicates "bandwidth normal" - has now been working like a charm for an hour w/o any signal drops.
Great, thnx.
BR - Timo
