fatal error after update to 4.4 **solved**
fdmarder1
Post by fdmarder1 »
Hi, after update to version Version 4.4/released September 19/20, 2020I got the following message:
2020-09-21 11:19:02 Error: 2020-09-21 11:19:01 <br /> <b>Fatal error</b>: date_create(): Timezone database is corrupt - this should *never* happen! in <b>/tmp/mnt/PWS/MB/mbdbfiles/nanocron.php</b> on line <b>6</b><br /> (no more tries)
No improvement after "Neustart".
Also not possible to open weather34-cockpit and the local 34template.
Windows 10 Firefox, Meteobridge Nano SD ,
Regards Gerd
Re: fatal error after update to 4.4
I cannot confirm. former local weather34 dashboard (implemented on "weather network" tab) works still fine on my NANO SD. Must be something specific with your installation. When exactly does the error occur? You shared very little information so far.
Please try "reset" button on local Dashboard on "weather network" tab, which initiates a reboot and reload of the weather34 stuff.
fdmarder1
Post by fdmarder1 »
Hi, thx for your hint, after
"Please try "reset" button on local Dashboard on "weather network" tab, which initiates a reboot and reload of the weather34 stuff."
all works fine
Regards Gerd
