error connect socket 10.0.1.2 (22): port 22222: Invalid argument. **solved**
mthiessen
Post by mthiessen »
A problem has all of a sudden come up with NanoSD. It doesn't seem to be receiving weather data from the sensor. Although WU is showing it's being updated regularly, WU doesn't show any weather data, it's all blank. I haven't made any changes except for installing the regular updates. Live Data --> Upload Status shows it's successfully sending to weather nets but they aren't receiving any weather data. NanoSD doesn't appear to be receiving data from Console.
This is at a vacation home across the country so I can only troubleshoot so much. I have remotely cycled power on the Davis Console and the WiFi router.
https://www.wunderground.com/dashboard/pws/KIDLEWIS13
Here is the log after rebooting NanoSD
database (21.09.2020 03:34:40): process started.
database (21.09.2020 03:34:40): Content of RAM database restored.
wnetd  (21.09.2020 03:34:44): process started.
system (21.09.2020 03:34:44): start of logging process initiated.
wnetd  (21.09.2020 03:34:44): send data thread started (pid:1909 tid:1910)
logger (21.09.2020 03:34:45): databases connected. Update interval 3600 seconds.
logger (21.09.2020 03:34:45): data logger (version 5.1d, build 3357) started.
logger (21.09.2020 03:34:46): station 0 (Vantage), error connect socket 10.0.1.2 (22): port 22222: Invalid argument
logger (21.09.2020 03:34:46): connect station 9 (System Data via Plug-in).
logger (21.09.2020 03:34:50): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (21.09.2020 03:34:50): services paused.
database (21.09.2020 03:34:55): database sync done (31 tables, 5/2476 writes).
logger (21.09.2020 03:35:16): station 0 (Vantage), error connect socket 10.0.1.2 (22): port 22222: Invalid argument
logger (21.09.2020 03:36:46): message above repeats 3 times.
logger (21.09.2020 03:36:47): give up waiting for sensors after 120 secs.
logger (21.09.2020 03:36:47): services activated.
logger (21.09.2020 03:37:16): station 0 (Vantage), error connect socket 10.0.1.2 (22): port 22222: Invalid argument
logger (21.09.2020 03:45:31): message above repeats 16 times.
system (21.09.2020 03:45:34): Disconnected from WLAN or Internet, reconnect issued.
system (21.09.2020 03:45:41): Access point operation temporarily enabled.
logger (21.09.2020 03:45:46): station 0 (Vantage), error connect socket 10.0.1.2 (22): port 22222: Invalid argument
logger (21.09.2020 03:50:46): message above repeats 10 times.
system (21.09.2020 03:50:48): Access point operation disabled 1072 secs after boot.
logger (21.09.2020 03:51:16): station 0 (Vantage), error connect socket 10.0.1.2 (22): port 22222: Invalid argument
Re: error connect socket 10.0.1.2 (22): port 22222: Invalid argument
No idea from looking at the log. NANO tries to connect to a console via TCPIP. Did you change settings there?
Can you grant me remote access? Please send URL and password to info(at)meteobridge.com.
Newest version does fix that.
