I was changing some settings today 23/9/2020 and the meteobridge forst lost the full configuration, and after a second reboot it was not accessible anymore.
Is there a way to go factory resets and bring my meteobrigde Pro alive again?
Meteobridge dead after reboot today (version 4.4?)
Re: Meteobridge dead after reboot today (version 4.4?)
Yes. Is the red LED in fast blinking mode? if so press the button behind the pinhole on the front panel. The display should show the options to choose from. Each time you press the button the cursor moves to the next item, when you have selected the option you require then wait for the progress to time out.
I indeed pressed the with a needle the 'reset' button, but the display remains dead, no 'reset' menu is offered. and the top led (red) remains on.
also tried power off/ on cycle, then the red led starts flashing, but can't reach the reset menu options
Powered down the unit for a few minutes, and now I can enter the recovery menu for factory reset
