Weather 34
MeteoOudkarspel
Weather 34
Post by MeteoOudkarspel »
Who can help where to install files from the Weather34-MB-SMART-Console-master-9.34.zip?
I personally think that meteobridge pro black should be installed on an internal USB stick, but in which folder should be the whole?
Thanks in advance for your help.
Sincerely,
Re: Weather 34
The weather34 templates will not work locally on MB PROs as they need PHP installed which will not fit onto the MB PROs.
Currently they are only available on MB NANO. When you try install SW components on your own on the PRO, you are on your own.
However, you can make use of the Weather34 templates on an external server. No limits there.
