open named pipe "/dev/meteobridge" failed
thunderstorm
Post by thunderstorm »
Just got following error on my NanoSD 'open named pipe "/dev/meteobridge" failed: Invalid argument'
A reboot helped, but is there anything else one could do ?
Bernd
logger (29.09.2020 10:20:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (29.09.2020 10:22:56): message above repeats 52 times.
database (29.09.2020 10:23:00): process terminated normally.
logger (29.09.2020 10:23:00): parent process received termination signal (15).
logger (29.09.2020 10:23:00): child process received termination signal (15).
logger (29.09.2020 10:23:00): disconnect station 0 (Vantage): exit
logger (29.09.2020 10:23:00): disconnect station 1 (User-defined): exit
logger (29.09.2020 10:23:00): disconnect station 2 (AirLink): exit
logger (29.09.2020 10:23:00): disconnect station 9 (System Data): exit
logger (29.09.2020 10:23:01): data logger stopped.
logger (29.09.2020 10:23:01): databases disconnected.
logger (29.09.2020 10:23:01): parent process to be terminated.
system (29.09.2020 10:23:57): stop of logging process initiated.
database (29.09.2020 10:23:58): process started.
system (29.09.2020 10:24:01): start of logging process initiated.
logger (29.09.2020 10:24:01): databases connected. Update interval 3600 seconds.
logger (29.09.2020 10:24:01): data logger (version 5.1d, build 3397) started.
system (29.09.2020 10:24:02): Access point operation disabled 13360 secs after boot.
logger (29.09.2020 10:24:03): connect station 0 (Vantage via USB serial).
logger (29.09.2020 10:24:03): connect station 1 (User-defined via Plug-in).
logger (29.09.2020 10:24:03): connect station 2 (AirLink via SW Driver).
logger (29.09.2020 10:24:03): connect station 9 (System Data via Plug-in).
logger (29.09.2020 10:24:03): station 0 (Vantage), wakeup sent.
logger (29.09.2020 10:24:04): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.09.2020 10:24:04): services paused.
database (29.09.2020 10:24:14): database sync done (33 tables, 38/2640 writes).
logger (29.09.2020 10:24:15): station 0 (Vantage), execution of setup script failed (console is not responding).
logger (29.09.2020 10:24:15): station 0 (Vantage), internal logger activated.
logger (29.09.2020 10:24:15): station 0 (Vantage), syncing.
logger (29.09.2020 10:24:15): station 0 (Vantage), gettime request sent.
logger (29.09.2020 10:24:15): station 0 (Vantage), no Vantage time offset.
logger (29.09.2020 10:24:15): station 0 (Vantage), eeprom request sent.
logger (29.09.2020 10:24:15): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (29.09.2020 10:24:15): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (29.09.2020 10:24:15): station 0 (Vantage), firmware version request sent.
logger (29.09.2020 10:24:15): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (29.09.2020 10:24:15): station 0 (Vantage), no reading of Vantage's internal logger.
logger (29.09.2020 10:24:20): sensors are now providing data.
logger (29.09.2020 10:24:20): services started.
logger (29.09.2020 10:24:20): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (29.09.2020 10:49:00): message above repeats 477 times.
