Import Data into WSWin
Expalmi
Post by Expalmi »
I successfully switched from Meteohub to Meteobridge pro, thank you Boris for quick software buck fixes.
I also could get Meteobridge PRO and WSWin work together.
I have three days missing in WSWin so I tried to export the data and import them into WSWin
Bildschirmfoto 2020-10-04 um 14.28.25.png (145.31 KiB) Viewed 3163 times
I used the Minutes button.
Importing this file does not show any data within WSWin.
What could be my error?
Andreas
Re: Import Data into WSWin
If you post the first lines of the export file here, we would have a chance to say something useful about it.
I really like the idea of "buck fixes", sorry for picking this as I am also a non-native speaker and struggle myself...
but this is really a lovely one... would be great if fixes bring me bucks, currently it looks more like work :lol:
Expalmi
Post by Expalmi »
Hi Boris,
you are right, I am also not a native speaker, and I often trust the autocorection of my Mac, and do not read my posting a second time
I also can laugh with this nice bug.
Here are the first rows of my export file
,,1,2,13,17,18,133,34,35,36,45,41,42
01.10.2020,00:00,22.3,14.2,--,59,94,1008.8,0.000,0.0,228,3.2,0.0,0
01.10.2020,01:00,22.3,13.9,--,59,93,1008.1,0.000,0.0,214,8.0,0.0,0
01.10.2020,02:00,22.3,13.2,--,59,91,1007.2,0.000,0.0,139,4.8,0.0,0
01.10.2020,03:00,22.2,12.5,--,59,92,1006.5,0.000,0.0,158,9.7,0.0,0
01.10.2020,04:00,22.2,12.0,--,59,92,1005.6,0.000,0.5,123,6.5,0.0,0
Data is separated by comma (not semicolon). Are there options in WSWIN to define which kind of format is used?
Rule of thumb: comma is US, semicolon is German.
Expalmi
Post by Expalmi »
I did not find any setting, within WSWin, to set the type of separator.
The template Wswin-monthly is build with comma.
Could it be, I am the first testing this feature?
No, for sure not. :D
Can you please send the file to be imported to info(at)smartbedded.com? I might reach out to Werner to ask, what makes WSWIN not to accept the import. Does "Dateiüberwachung" for current data work?
Expalmi
Post by Expalmi »
ok, when others can import the data, it may take time, but I will find the problem.
Werner gave me some hints:
>... was einstellen um ";" oder "," als Trennzeichen zu akzeptieren oder geht beides automatisch?
geht alles automatisch nur nicht gemischt in einer Zeile 😉
So wie es aussieht, gibt es keine Daten für die ID=13 -> Wert = "--" (irgendwas mit Bodentemperatur)
Eigentlich werden Daten mit "--" ignoriert, in älteren Wswin - Versionen aber nicht.
Möglicherweise nutzt er eine ältere Version.
Meine Empfehlung Daten von 13 in diesem Fall nicht in csv-Datei schreiben lassen.
habe gerade gelesen:
Wenn für Oktober schon Daten vorhanden sind, werden beim Import nur neuere Daten übernommen.
Das scheint hier der Fall zu sein:
er muss in diesem Fall, die vorhandenen Daten exportieren, Datei umbenennen/sichern,
Die Daten der ersten 3 Tage importieren und die vorher exportierten Daten wieder importieren.
Please try this "wswin-monthly-new.exp" file to be located in the templates folder:
#pragma exportfile=EXP[MM]_[YY].csv
#pragma crlf=y
#pragma fillgap=300
## Datum, Zeit, Innentemperatur[C], Aussentemperatur [C], Innenfeuchte [%], Aussenfeuchte [%], LuftdruckMeereshoehe [hPa], Regen [mm], Windgeschwindigkeit[km/h], Windrichtung, Böen[km/h], UV-Index, Solarstrahlung [W]
$,,1,2,13,17,18,133,34,35,36,45,41,42
[DD].[MM].[YYYY],[hh]:[mm],[thb0temp-avg.1:],[th0temp-avg.1:],[th10temp-avg.1:],[thb0hum-avg.0:],[th0hum-avg.0:],[thb0seapress-avg.1:],[rain0total-sum.3:],[wind0avgwind-avg=kmh.1:],[wind0dir-avg.0:],[wind0wind-max=kmh.1:],[uv0index-avg.1:],[sol0rad-avg.0:]
It does not output the "--" in case a sensor is missing but just returns nothing in that case. If this cures the problem, I will make it the WSWIN export default file.
