Low battery warning. **solved**
Post by 36260 »
I'm running a Davis VP2 with a repeater with Nano SD. In Meteobridge documentation, I noticed there are lotbat sensors. I'm wondering whether there is a way to report low battery conditions either on the station or the repeater.
Thank you
Davis VP2 + Solar - Nano SD
MS72@MH
Re: Low battery warning
Post by MS72@MH »
please take a look at the 'History' tab. The sensor should be logged automatically.
On the tab 'Service' you can try to create a one-time alert to send an email. Set 'Raise' to something like this: [thb3lowbat-act:0]==1
36260
Post by 36260 »
MS72@MH wrote: Tue Oct 13, 2020 1:51 pm please take a look at the 'History' tab. The sensor should be logged automatically.
Thank you very much for your answer. Indeed, I'm aware of this tab. But I'm afraid lowbat is related to a specific sensor not to the station itself nor the repeater. I recently experienced a battery shortage on the repeater and none of lowbat sensors reported a 1 value.
Battery status of a repeater is not monitored by Meteobridge.
36260
Post by 36260 »
Thanks. What about the station itself?
Do you mean the console? Meteobridge PRO red does not connect to the console, so it cannot say anything about it.
36260
Post by 36260 »
No I'm referring to the VP2 ISS station, where all the sensors are
Re: Low battery warning **solved**
sensors will get lowbat indicators when this comes true.
36260
Re: Low battery warning. **solved**
Post by 36260 »
Thank you
