Outdoor Temp disappear after last soft upgrade - WMR200 **solved**
Posted: Wed Oct 14, 2020 9:07 am
by Mirek
Dear Friends
I am using new meteobridge (bought in this year in meteo shop) on TL-MR3020v3 (plus USB hub) with WMR200 (because anywhere weather is discontinued). In this system I need access to my 7 additionally tempereture and humidity sensors via internet from outside.
Every thing work excellent until last automaticaly soft upgrade with date Oct. 6. 2020 – disappear outdoor temperature and humidity in meteobridge. On Raw Sensor Data is missing 0 Outdoor temperature and on Min/Max Data in 0 outdoor temperature and 0 outdoor humidity are „tresh-cans”.
Meteobridge send to Wunderground outdoor temperature from physical ch.2 (ought to be from ch.1). Wundreground shaw outdoor humidity as „- -„.
I did a lot of experiments with outdoor temperature sensor ch.1 but WMR200 display this data correct always (RF connection is excellent).
Now pass few software upgrades but problem with outdoor temperature on meteobridge from WMR200 stay.
Could You try to help, please? I am not IT expert.
Mirek
Re: Outdoor Temp disappear after last soft upgrade - WMR200
Posted: Thu Oct 15, 2020 10:44 pm
by martin
it seems I have the same problem, meteobridge does not find the outdoor temp anymore.
I have tried serveral things like reboot, reset, reconect the temp sensor to the mwr200. changed the primary station, setup of sensors, mapping of the sensors.
The wmr200 displays the expected outdoor temp, meteo bridge doesn't. :(
Has anyone a clue whats going on, how to solve this issue.
thanks,
Schermafbeelding 2020-10-15 224305.jpg (49.43 KiB) Viewed 2024 times
Schermafbeelding 2020-10-15 224222.jpg (131.52 KiB) Viewed 2024 times
Schermafbeelding 2020-10-15 224149.jpg (61.25 KiB) Viewed 2024 times
Posted: Fri Oct 16, 2020 8:18 am
by Mirek
Hi Martin
Thank you, that You write about this issue.
Now we are both with the same problem.
Yesterday 14-10-2020 was next automatic soft upgrade but outdoor temperature and outdor humidity is missing still.
It is look like same issue with numbering of temperature sensor from ch.1 and ch.2 displayed as 0 outdoor temperature (0th0!0temp) and 0 outdoor #1 (0th0!1temp). Wunderground shaw data from ch.2. (0t0!1temp).
Mirek
Posted: Fri Oct 16, 2020 9:38 am
by martin
Hi Mirek,
you're welcome
The first time I remarked this issue was after a restart of meteobridge on october, 9th. Due to a power issue.
first I though, the issue was due a the power failure.
Last wednesday, I started to look more in detail to the problem. did some tests and reboots.
So it looks like the issue exists already before the 14th.
I have one outdoor temp sensor, it should be listed as th0temp (without the b, insite temp).
I've also send a mail to info@smartbedded.com this morning.
Martin
Posted: Sat Oct 17, 2020 4:57 pm
Strange. Can you please provide me a remote login? please send credentials to "info@meteobridge.com".
Re: Outdoor Temp disappear after last soft upgrade - WMR200: SOLVED
Posted: Sun Oct 18, 2020 1:08 pm
by Mirek
Dear Frieds
After soft upgrade Oct.18 2020 build 3503 system with WMR200 works excellent.
Thank you very much for help
and
All the best
Mirek
Posted: Sun Oct 18, 2020 1:59 pm
by martin
My system is also up and running again, the new build of today is performing good. :D
Thanks for solving this issue that quickly.
good luck
Martin
