Conversion degress ---> english direction wind. **solved**
Luca02
Post by Luca02 »
Is it possibile to convert wind direction in normal meteobridge from degrees to english directions text? I'm not so good in html language and variables... thank you so much for help :D
PS Another question: how i can convert from UTC to local clock time?
Re: Conversion degress ---> english direction wind
Luca02 wrote: Wed Nov 04, 2020 4:19 pm Hi,
Check this : https://www.meteobridge.com/wiki/index.php/Templates
endir converts a wind direction into one of 16 English direction texts.
wind0dir-act=endir
Default a Meteobridge returns the timestamps not in UTC but in your local time as you set your local timezone,
"Timestamps are strings of format "YYYYMMDDhhmmss".
You have to set it to =utc to get an utc timestamp.
Luca02
Post by Luca02 »
Hi Wim,
thank you so much for help, but i notice something wrong on my website page.
Meteobridge report a gust from SE, but on my website it is reported from E, also SW becomes W.
This is the variable expressed: [wind0dir-act=endir.1:—]
How can i fix?
Luca02 wrote: Wed Nov 04, 2020 7:55 pm Hi Wim,
How can i fix?
The .1 makes it one position returned.
Better use [wind0dir-act=endir:--]
After the : it is the value returned if there is no value available, such as with a broken wind-device.
Luca02
Re: Conversion degress ---> english direction wind. **solved**
Post by Luca02 »
Thank you so much Wim! sorry for the stupid question
