Nano SD stopped sending data
thunderstorm
Post by thunderstorm »
My nano sd stopped reporting data to all services and I can see the following message in the logs
logger (15.11.2020 17:31:55): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (15.11.2020 17:45:22): message above repeats 261 times
It seems to work again after I restarted the device
Re: Nano SD stopped sending data
Have there been more messages before that, which might indicate the reason?
thunderstorm
Nothing suspicious, the line before was an entry at 17:00 similar to this
export (15.11.2020 19:00:06): 1141 lines of data written to file: 20201115log.txt
36260
Post by 36260 »
I had a similar issue. When this arises, could check in system/info tab the buffer value. If it is 1000 then something is wrong. Update you software and it will be fixed.
Davis VP2 + Solar - Nano SD
