Raspi Meteobridge Aculink **solved**
hymrog
Post by hymrog »
Hi
I have been using the Aculink/Smarthub with meteobridge on the TL-MR3020 since the inception of meteobridge and have experienced no major issues with functioning of the unit even after the Smarthubs demise (using acuparse and have a dns override on my router to spoof the acurite hubcap site). I see that there is still an option to use the Aculink/Smarthub with the raspberry pi and I have set all the necessary options but cannot seem to get system to work.
Log from the meteobridge pi
logger (15.11.2020 16:51:50): connect station 0 (AcuLink via SW Driver).
logger (15.11.2020 16:51:50): connect station 9 (System Data via Plug-in).
logger (15.11.2020 16:51:53): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (15.11.2020 16:51:53): services paused.
logger (15.11.2020 16:53:53): give up waiting for sensors after 120 secs.
logger (15.11.2020 16:53:53): services activated.
logger (15.11.2020 17:02:20): child process received timeout signal (14).
logger (15.11.2020 17:02:20): disconnect station 0 (AcuLink): exit
logger (15.11.2020 17:02:20): disconnect station 9 (System Data): exit
logger (15.11.2020 17:02:21): data logger stopped.
Before anyone goes on to say that the acurite and the 5in1 is junk I can tell you I have had the same unit for 7 years with only one minor hiccup and that was soldering in a new temp/hum sensor after the original failed. Furthermore,the accuracy of the unit is fairly spot on as I am usually in sync with a neighbors Davis along with the local internatiion airport...so needless to say I would like to keep this old dog rolling with the robust features included with the meteobridge pi if at all possible.
Thanks for looking
g
Re: Raspi Meteobridge Aculink
Aculink is dead since years and only operational with additional DNS spoofing. If you give me remote login, I can have a look.
But to be honest, just drop this dead stuff the manufacturer has pulled the trigger on.
hymrog
Post by hymrog »
Info sent. Thanks for looking
g
latest upodate does fix this.
