NanoSD wind speed. **solved**
atlantic21
Post by atlantic21 »
Is it possible to change the wind speed from m/s to mph as viewed in the min/max tab but i would like to keep rain in mm/temp in oc and pressure in mb
wind speed.png (15.84 KiB) Viewed 1300 times
Re: NanoSD wind speed
This page is meant as a technical inspection tab. It does not provide customizations. The weather34 dashboard included into your NANO SD might better fit your needs.
atlantic21
Ok thanks
