Secondary Temp Sensor missing after reboot. **solved**
ilovehd
Post by ilovehd »
Hello all. I have a meteobridge that was running ver 3.7 until today when i rebooted and picked up ver 5.0. Ok usually not a problem except I am missing my second temp sensor. I am running a Davis vantage pro2 wireless weather station with a secondary wireless temp sensor. This is what I see in my log file- some weird stuff.
logger (28.11.2020 17:10:08): services started.
logger (28.11.2020 17:10:16): station 0 (Vantage), gettime request sent.
logger (28.11.2020 17:10:16): station 0 (Vantage), no Vantage time offset.
logger (28.11.2020 17:10:16): station 0 (Vantage), eeprom request sent.
logger (28.11.2020 17:10:16): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (28.11.2020 17:10:16): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (28.11.2020 17:10:16): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (28.11.2020 17:10:16): station 0 (Vantage), transmitter 3 active as station type #1 "Temp Only" mapped to "t1".
logger (28.11.2020 17:10:16): station 0 (Vantage), firmware version request sent.
logger (28.11.2020 17:10:16): station 0 (Vantage), firmware version 1.80
logger (28.11.2020 17:10:16): station 0 (Vantage), no reading of Vantage's internal logger.
logger (28.11.2020 17:10:16): station 0 (Vantage), 192.168.1.238's request on port 22222 accepted.
logger (28.11.2020 17:10:19): station 0 (Vantage), connection on port 22222 closed.
logger (28.11.2020 17:10:20): station 0 (Vantage), 192.168.1.238's request on port 22222 accepted.
logger (28.11.2020 17:10:29): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (28.11.2020 17:10:43): message above repeats 7 times.
logger (28.11.2020 17:10:56): station 0 (Vantage), connection on port 22222 closed.
logger (28.11.2020 17:10:58): station 0 (Vantage), 192.168.1.238's request on port 22222 accepted.
logger (28.11.2020 17:11:06): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (28.11.2020 17:11:41): message above repeats 18 times.
logger (28.11.2020 17:11:54): station 0 (Vantage), connection on port 22222 closed.
logger (28.11.2020 17:11:56): station 0 (Vantage), 192.168.1.238's request on port 22222 accepted.
logger (28.11.2020 17:12:04): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (28.11.2020 17:12:44): message above repeats 20 times.
My live sensor data doesn't even show my secondary temp sensor and I don't understand the errors above about the bad sensor data - all was working fine until the reboot - new FW.
Upload StatusRaw Sensor DataMin/Max Data
Live Data
# Sensor Signal Metric Data Imperial Data
0 Outdoor 51 sec 5.8°C 69% (dew 0.6°C, heat 5.8°C) 42.4°F 69% (dew 33.1°F, heat 42.4°F)
0 Indoor 13 sec 21.8°C 31% 1013.3hPa (976.2hPa) 71.2°F 31% 29.92inHg (28.83inHg)
0 Wind 1 sec 1.8m/s (avg 2.2m/s) 225° SW 4.0mph (avg 4.9mph) 225° SW
0 Rain 13 sec rate 0.0mm/h rate 0.00in/h
Any help would be apprecaited!
BigAlT
Re: Secondary Temp Sensor missing after reboot
Post by BigAlT »
Why don’t you reboot into System 4.4 ( using the version control drop down menu ). If that works correctly, then reboot into the newest version 5.0 and see if it just might have been a corrupted download.
ilovehd
Post by ilovehd »
I'll try that when I am back in town. I reverted to 4.2 and all seems fine.
There is a new release out, which should handle extra sensors fine again.
ilovehd
Post by ilovehd »
That seems to have fixed the issue! Thanks!
