Bad sensor data
JWR
Bad sensor data
Post by JWR »
I have since this morning the following message:
Bad th0(0) sensor data, "temperature x10" (-672) out of range [-500:2000]
Do someone know how I can solve this problem?
Meteobridge 5.0 (Nov 28 2020, build 3626), FW 1.4
bzb
Re: Bad sensor data
Post by bzb »
Hi
First.
I'm very new to this Forum and also to meteobridge, because we get one recently and i never had one before. Also, I'm not a deeply experienced Weather-Station User.
I'm facing the same Errormessage. But in my Case, it seams that every Value and Sensor is reporting correct.
We have a
Davis Vantage Vue, Pro2, Pro1 (FW B), Envoy
Connectet to
System:
Plattform: TL-MR3020V3 (without HUB)
SW-Version: Meteobridge 5.0 (Nov 28 2020, build 3626), FW 1.3
Here are the Live Sensor Values
Live Data
# Sensor Signal Metric Data Imperial Data
0 Outdoor 6 sec 0.8°C 81% (dew -2.1°C, heat 0.8°C) 33.4°F 81% (dew 28.2°F, heat 33.4°F)
0 Indoor 50 sec 21.6°C 45% 1027.2hPa (960.8hPa) 70.9°F 45% 30.33inHg (28.37inHg)
0 Solar 36 sec 62W/m² 62W/m²
0 Wind 14 sec 0.4m/s (avg 1.3m/s) 240° WSW 0.9mph (avg 2.9mph) 240° WSW
0 Rain 20 sec rate 0.0mm/h rate 0.00in/h
And here is the Original Log from our Meteobridge:
I hope someone see my fault.
wnetd (30.11.2020 09:10:09): process started.
system (30.11.2020 09:10:09): start of logging process initiated.
wnetd (30.11.2020 09:10:09): send data thread started (pid:9249 tid:9250)
logger (30.11.2020 09:10:09): historical data loaded (23 records).
logger (30.11.2020 09:10:09): data logger (version 5.1d, build 3626) started.
logger (30.11.2020 09:10:10): station 0 (Vantage), can't open device /dev/ttyMH: Invalid argument
logger (30.11.2020 09:10:10): station 0 (Vantage), connect to station failed.
logger (30.11.2020 09:10:13): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (30.11.2020 09:10:13): services paused.
logger (30.11.2020 09:10:40): station 0 (Vantage), can't open device /dev/ttyMH: Invalid argument
logger (30.11.2020 09:11:40): message above repeats 2 times.
logger (30.11.2020 09:12:10): give up waiting for sensors after 120 secs.
logger (30.11.2020 09:12:10): services activated.
logger (30.11.2020 09:12:10): station 0 (Vantage), can't open device /dev/ttyMH: Invalid argument
logger (30.11.2020 09:13:40): message above repeats 3 times.
logger (30.11.2020 09:14:10): connect station 0 (Vantage via USB serial).
logger (30.11.2020 09:14:10): station 0 (Vantage), wakeup sent.
logger (30.11.2020 09:14:14): station 0 (Vantage), no need to update console date/time.
logger (30.11.2020 09:14:15): station 0 (Vantage), setup script executed.
logger (30.11.2020 09:14:15): station 0 (Vantage), internal logger activated.
logger (30.11.2020 09:14:15): station 0 (Vantage), syncing.
logger (30.11.2020 09:14:25): station 0 (Vantage), gettime request sent.
logger (30.11.2020 09:14:25): station 0 (Vantage), no Vantage time offset.
logger (30.11.2020 09:14:25): station 0 (Vantage), eeprom request sent.
logger (30.11.2020 09:14:25): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (30.11.2020 09:14:25): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (30.11.2020 09:14:25): station 0 (Vantage), transmitter 5 active as station type #4 "Wind".
logger (30.11.2020 09:14:25): station 0 (Vantage), transmitter 8 active as station type #1 "Temp Only" mapped to "t1".
logger (30.11.2020 09:14:25): station 0 (Vantage), firmware version request sent.
logger (30.11.2020 09:14:25): station 0 (Vantage), firmware version 1.70
logger (30.11.2020 09:14:25): station 0 (Vantage), no reading of Vantage's internal logger.
logger (30.11.2020 09:14:29): Bad t0(0) sensor data, "temperature x10" (-672) out of range [-500:2000]
logger (30.11.2020 09:15:30): message above repeats 32 times.
logger (30.11.2020 09:15:32): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (30.11.2020 09:19:58): message above repeats 129 times.
logger (30.11.2020 09:20:00): Bad t0(0) sensor data, "temperature x10" (-672) out of range [-500:2000]
logger (30.11.2020 09:26:19): message above repeats 180 times.
logger (30.11.2020 09:26:21): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (30.11.2020 09:56:35): message above repeats 862 times.
logger (30.11.2020 09:56:37): Bad t0(0) sensor data, "temperature x10" (-672) out of range [-500:2000]
logger (30.11.2020 10:02:08): message above repeats 158 times.
logger (30.11.2020 10:02:11): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (30.11.2020 11:44:25): message above repeats 2908 times.
logger (30.11.2020 11:44:28): Bad t0(0) sensor data, "temperature x10" (-672) out of range [-500:2000]
logger (30.11.2020 11:46:17): message above repeats 53 times.
logger (30.11.2020 11:46:19): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (30.11.2020 12:00:44): message above repeats 412 times.
logger (30.11.2020 12:00:47): Bad t0(0) sensor data, "temperature x10" (-672) out of range [-500:2000]
logger (30.11.2020 12:03:13): message above repeats 71 times.
logger (30.11.2020 12:03:27): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (30.11.2020 12:14:01): message above repeats 308 times.
logger (30.11.2020 12:14:03): Bad t0(0) sensor data, "temperature x10" (-672) out of range [-500:2000]
logger (30.11.2020 12:14:59): message above repeats 28 times.
logger (30.11.2020 12:15:01): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (30.11.2020 12:15:03): message above repeats 1 time.
logger (30.11.2020 12:15:05): Bad t0(0) sensor data, "temperature x10" (-672) out of range [-500:2000]
logger (30.11.2020 12:15:57): message above repeats 24 times.
logger (30.11.2020 12:15:59): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (30.11.2020 12:17:14): message above repeats 34 times.
logger (30.11.2020 12:17:16): Bad t0(0) sensor data, "temperature x10" (-672) out of range [-500:2000]
logger (30.11.2020 12:18:30): message above repeats 36 times.
logger (30.11.2020 12:18:31): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (30.11.2020 12:25:11): message above repeats 190 times.
logger (30.11.2020 12:25:13): Bad t0(0) sensor data, "temperature x10" (-672) out of range [-500:2000]
logger (30.11.2020 12:30:01): message above repeats 138 times.
logger (30.11.2020 12:30:03): Bad t0(0) sensor data, "temperature x10" (-678) out of range [-500:2000]
logger (30.11.2020 12:32:05): message above repeats 59 times.
Re: Bad sensor data
Please try todays update.
