Page 1 of 2
Re: Meteobridge supports Raspberry Pi 3B, 3B+, 4B
Posted: Sat Nov 28, 2020 12:08 pm
by norvegese
I just changed the device and now I have put a raspberry and I have already moved the license but I can not modify the historical data min / max
why ?
Posted: Sat Nov 28, 2020 12:09 pm
Do you have a supported microSD card? Do you see the "History" and "Graphs" tab?
Posted: Sat Nov 28, 2020 2:17 pm
by norvegese
yes the card is supported! it is more or less three hours that it is in operation
Posted: Sat Nov 28, 2020 2:21 pm
by norvegese
with history this writing comes out:
The proxy server received an invalid response from an upstream server.
Posted: Sat Nov 28, 2020 2:42 pm
norvegese wrote: Sat Nov 28, 2020 2:21 pm
proxy server? are you trying to access it remotely?
As your English is hard to understand (at least for me), can you please provide screen dumps? I am really guessing what your issue might be.
Posted: Sat Nov 28, 2020 6:17 pm
by norvegese
sorry i was out for work what screens do you need?
Posted: Sat Nov 28, 2020 6:59 pm
by norvegese
if I click on history this page comes out with this writing:
Bad Gateway
and even if I click on the weather data to change them
Posted: Mon Nov 30, 2020 10:36 am
by norvegese
but no one can help me?
Rpi problem history
Posted: Mon Nov 30, 2020 2:23 pm
by norvegese
I have a problem with the raspberry pi 4 the history does not work and I can not update min and max this message comes out:
Bad Gateway
Re: Rpi problem history
Posted: Mon Nov 30, 2020 3:40 pm
by wvdkuil
norvegese wrote: Mon Nov 30, 2020 2:23 pm
Bad Gateway
As asked before mak a screen-shot of the system tab
and
Make a screen-shot of what shows on the minute tab.
See an example I attached of my raspberry
Posted: Mon Nov 30, 2020 4:25 pm
by norvegese
- C2605BBD-0C00-4DA2-BE96-1DD4CF20F145.jpeg (40.31 KiB) Viewed 4670 times
Posted: Mon Nov 30, 2020 4:33 pm
by norvegese
- 0D0A96E7-0702-4539-9492-74B764D00EB8.jpeg (198.96 KiB) Viewed 4670 times
Posted: Mon Nov 30, 2020 6:17 pm
by wvdkuil
Well I almost sure that you need a larger SLC card to get the / minute data.
viewtopic.php?p=35823#p35823
The trigger to make this new feature was based on the availability of affordable 8 or 16 Gb SLC cards
Your SLC card would wear out in less than 1 year if /minute data would be stored.
I am also not sure if this is already available or that you need to apply for a beta-version first.
But it is unexplained why your / hour data does not work.
That should always work on any raspberry. See screenshot
What happens when you click on the "Edit Hour Data" tab? (Strangly it is the only one untranslated also.)
Can you make a screenshot what happens when you click that?
Posted: Mon Nov 30, 2020 6:43 pm
by wvdkuil
Posted: Mon Nov 30, 2020 7:28 pm
by norvegese
This happens ad son as press
- FF9AF129-8F50-4AC3-B488-8403B1F1DDBD.png (55.89 KiB) Viewed 4636 times
