Airlink Outdoor/ Indoor temperature.
MeteoLeudal
Post by MeteoLeudal »
Hi Admin,
Use MB SW on an RPi 4B. For station 1 added a Davis Airlink, which monitors the AQ inside a building. Is it possible to create a button or something similar to switch from outdoor to indoor Airlink use in one of the next updates?
Davis Airlink.JPG (206.62 KiB) Viewed 1188 times
galfert
Re: Airlink Outdoor/ Indoor temperature.
Post by galfert »
Since the use of the Airlink is indicated by Davis that it can be installed indoor or outdoor, then this temperature / humidity sensor should be referred to as "Extra" as this is the current implementation for other sensors that can be installed indoor or outdoor.
Meteobridge RPI | GW1000
