Any thoughts?database (11.12.2020 15:49:38): process started.
database (11.12.2020 15:49:38): Content of RAM database restored.
wnetd (11.12.2020 15:49:40): process started.
system (11.12.2020 15:49:41): start of logging process initiated.
wnetd (11.12.2020 15:49:41): send data thread started (pid:2016 tid:2017)
logger (11.12.2020 15:49:42): databases connected. Update interval 3600 seconds.
logger (11.12.2020 15:49:42): data logger (version 5.1d, build 3662) started.
logger (11.12.2020 15:49:44): connect station 0 (Vantage via serial).
logger (11.12.2020 15:49:44): connect station 1 (AirLink via SW Driver).
logger (11.12.2020 15:49:44): connect station 9 (System Data via Plug-in).
logger (11.12.2020 15:49:44): station 0 (Vantage), wakeup sent.
logger (11.12.2020 15:49:46): station 0 (Vantage), no need to update console date/time.
logger (11.12.2020 15:49:46): station 0 (Vantage), setup script executed.
logger (11.12.2020 15:49:46): station 0 (Vantage), internal logger activated.
logger (11.12.2020 15:49:46): station 0 (Vantage), syncing.
logger (11.12.2020 15:49:46): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (11.12.2020 15:49:46): services paused.
logger (11.12.2020 15:49:56): station 0 (Vantage), gettime request sent.
logger (11.12.2020 15:49:56): station 0 (Vantage), no Vantage time offset.
logger (11.12.2020 15:49:56): station 0 (Vantage), eeprom request sent.
logger (11.12.2020 15:49:56): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (11.12.2020 15:49:56): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (11.12.2020 15:49:56): station 0 (Vantage), transmitter 8 active as station type #4 "Wind".
logger (11.12.2020 15:49:56): station 0 (Vantage), firmware version request sent.
logger (11.12.2020 15:49:56): station 0 (Vantage), firmware version 4.33 (supports LOOP2)
logger (11.12.2020 15:49:56): station 0 (Vantage), no reading of Vantage's internal logger.
database (11.12.2020 15:50:00): database sync done (42 tables, 101/3360 writes).
logger (11.12.2020 15:50:02): sensors are now providing data.
logger (11.12.2020 15:50:02): services started.
system (11.12.2020 16:05:54): Access point operation disabled 1076 secs after boot.
logger (12.12.2020 21:06:55): station 1 (AirLink), unexpected 0 bytes.
logger (12.12.2020 21:06:55): disconnect station 1 (AirLink): response without data
logger (12.12.2020 21:07:25): connect station 1 (AirLink via SW Driver).
logger (12.12.2020 22:00:40): station 1 (AirLink), unexpected 0 bytes.
logger (12.12.2020 22:00:45): disconnect station 1 (AirLink): response without data
logger (12.12.2020 22:01:25): connect station 1 (AirLink via SW Driver).
logger (12.12.2020 22:07:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (12.12.2020 22:07:23): message above repeats 1 time.
wnetd (12.12.2020 22:07:28): process received SIGTERM signal (15) and terminated.
logger (12.12.2020 22:08:20): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (12.12.2020 22:10:25): message above repeats 8 times.
test5m (12.12.2020 22:11:11): weathernet daemon stalled, will be restarted now.
logger (12.12.2020 22:11:20): open named pipe "/dev/meteobridge" failed: Invalid argument
wnetd (12.12.2020 22:11:21): process started.
wnetd (12.12.2020 22:11:21): send data thread started (pid:23869 tid:23870)
logger (12.12.2020 22:12:47): station 1 (AirLink), unexpected 0 bytes.
logger (12.12.2020 22:12:47): disconnect station 1 (AirLink): response without data
logger (12.12.2020 22:14:50): child process received termination signal (15).
logger (12.12.2020 22:14:50): parent process received termination signal (15).
logger (12.12.2020 22:14:50): disconnect station 0 (Vantage): exit
logger (12.12.2020 22:14:51): disconnect station 9 (System Data): exit
logger (12.12.2020 22:15:25): data logger stopped.
logger (12.12.2020 22:15:25): databases disconnected.
logger (12.12.2020 22:15:25): parent process to be terminated.
test5m (12.12.2020 22:16:06): logger stalled, will be restarted now.
system (12.12.2020 22:16:07): stop of logging process initiated.
system (12.12.2020 22:16:28): start of logging process initiated.
logger (12.12.2020 22:16:34): databases connected. Update interval 3600 seconds.
logger (12.12.2020 22:16:34): data logger (version 5.1d, build 3662) started.
logger (12.12.2020 22:16:56): connect station 0 (Vantage via serial).
logger (12.12.2020 22:16:56): connect station 1 (AirLink via SW Driver).
logger (12.12.2020 22:16:56): connect station 9 (System Data via Plug-in).
logger (12.12.2020 22:16:56): station 0 (Vantage), wakeup sent.
logger (12.12.2020 22:16:59): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (12.12.2020 22:16:59): services paused.
logger (12.12.2020 22:16:59): station 0 (Vantage), no need to update console date/time.
logger (12.12.2020 22:16:59): station 0 (Vantage), setup script executed.
logger (12.12.2020 22:16:59): station 0 (Vantage), internal logger activated.
logger (12.12.2020 22:16:59): station 0 (Vantage), syncing.
logger (12.12.2020 22:17:09): station 0 (Vantage), gettime request sent.
logger (12.12.2020 22:17:09): station 0 (Vantage), no Vantage time offset.
logger (12.12.2020 22:17:09): station 0 (Vantage), eeprom request sent.
logger (12.12.2020 22:17:09): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (12.12.2020 22:17:09): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (12.12.2020 22:17:09): station 0 (Vantage), transmitter 8 active as station type #4 "Wind".
logger (12.12.2020 22:17:09): station 0 (Vantage), firmware version request sent.
logger (12.12.2020 22:17:09): station 0 (Vantage), firmware version 4.33 (supports LOOP2)
logger (12.12.2020 22:17:09): station 0 (Vantage), no reading of Vantage's internal logger.
logger (12.12.2020 22:17:14): sensors are now providing data.
logger (12.12.2020 22:17:14): services started.
logger (12.12.2020 22:41:02): station 1 (AirLink), unexpected 0 bytes.
logger (12.12.2020 22:41:04): disconnect station 1 (AirLink): response without data
logger (12.12.2020 22:41:34): connect station 1 (AirLink via SW Driver).
logger (12.12.2020 23:46:55): open named pipe "/dev/meteobridge" failed: Invalid argument
wnetd (12.12.2020 23:47:04): process received SIGTERM signal (15) and terminated.
logger (12.12.2020 23:47:09): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (12.12.2020 23:51:19): message above repeats 26 times.
test5m (12.12.2020 23:51:24): weathernet daemon stalled, will be restarted now.
wnetd (12.12.2020 23:51:26): process started.
wnetd (12.12.2020 23:51:26): send data thread started (pid:9736 tid:9743)
database (13.12.2020 00:06:32): cannot insert into 'th0temp_day' RAM (after 0 tries in 1ms): database or disk is full (13)
database (13.12.2020 00:06:32): rollback on insert forced (2) (hour): th0temp
database (13.12.2020 00:06:33): cannot commit RAM (after 0 tries in 1ms): database or disk is full (13)
database (13.12.2020 00:06:33): cannot rollback RAM (after 0 tries in 1ms): cannot rollback - no transaction is active (1)
database (13.12.2020 00:06:33): cannot insert into 'th0temp_hour' RAM (after 0 tries in 1ms): database or disk is full (13)
database (13.12.2020 00:06:33): rollback on insert forced (2) (min): th0temp
database (13.12.2020 03:31:24): cannot insert into 'th0temp_day' RAM (after 0 tries in 1ms): database or disk is full (13)
database (13.12.2020 03:31:24): rollback on insert forced (2) (hour): th0temp
logger (13.12.2020 03:56:06): station 1 (AirLink), unexpected 0 bytes.
logger (13.12.2020 03:56:11): disconnect station 1 (AirLink): response without data
logger (13.12.2020 03:56:41): connect station 1 (AirLink via SW Driver).
wnetd (13.12.2020 04:09:24): process received SIGTERM signal (15) and terminated.
logger (13.12.2020 04:10:01): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 04:11:05): message above repeats 5 times.
test5m (13.12.2020 04:11:07): weathernet daemon stalled, will be restarted now.
wnetd (13.12.2020 04:11:08): process started.
wnetd (13.12.2020 04:11:08): send data thread started (pid:850 tid:851)
wnetd (13.12.2020 04:15:19): process received SIGTERM signal (15) and terminated.
logger (13.12.2020 04:16:06): open named pipe "/dev/meteobridge" failed: Invalid argument
test5m (13.12.2020 04:16:22): weathernet daemon stalled, will be restarted now.
wnetd (13.12.2020 04:16:22): process started.
wnetd (13.12.2020 04:16:23): send data thread started (pid:3302 tid:3303)
logger (13.12.2020 05:15:33): station 1 (AirLink), unexpected 0 bytes.
logger (13.12.2020 05:15:34): disconnect station 1 (AirLink): response without data
logger (13.12.2020 05:16:04): connect station 1 (AirLink via SW Driver).
logger (13.12.2020 08:47:09): station 1 (AirLink), unexpected 0 bytes.
logger (13.12.2020 08:47:13): disconnect station 1 (AirLink): response without data
logger (13.12.2020 08:47:43): connect station 1 (AirLink via SW Driver).
logger (13.12.2020 09:14:24): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 09:14:27): message above repeats 2 times.
logger (13.12.2020 09:15:25): station 1 (AirLink), unexpected 0 bytes.
logger (13.12.2020 09:15:27): disconnect station 1 (AirLink): response without data
logger (13.12.2020 09:15:29): open named pipe "/dev/meteobridge" failed: Invalid argument
wnetd (13.12.2020 09:15:31): process received SIGTERM signal (15) and terminated.
logger (13.12.2020 09:15:57): connect station 1 (AirLink via SW Driver).
logger (13.12.2020 09:16:25): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 09:21:30): message above repeats 28 times.
test5m (13.12.2020 09:21:39): weathernet daemon stalled, will be restarted now.
wnetd (13.12.2020 09:21:49): process started.
wnetd (13.12.2020 09:21:50): send data thread started (pid:1137 tid:1429)
wnetd (13.12.2020 09:29:42): process received SIGTERM signal (15) and terminated.
logger (13.12.2020 09:29:45): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 09:45:05): message above repeats 50 times.
logger (13.12.2020 09:45:27): station 1 (AirLink), unexpected 0 bytes.
logger (13.12.2020 09:45:28): disconnect station 1 (AirLink): response without data
logger (13.12.2020 09:45:58): connect station 1 (AirLink via SW Driver).
logger (13.12.2020 09:46:02): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 10:15:37): message above repeats 107 times.
database (13.12.2020 10:15:51): cannot commit RAM (after 0 tries in 1ms): database or disk is full (13)
database (13.12.2020 10:15:51): cannot rollback RAM (after 0 tries in 1ms): cannot rollback - no transaction is active (1)
database (13.12.2020 10:15:51): cannot insert into 'rain0rate_hour' RAM (after 0 tries in 1ms): database or disk is full (13)
database (13.12.2020 10:15:51): rollback on insert forced (2) (min): rain0rate
database (13.12.2020logger (13.12.2020 10:16:50): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 10:17:29): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 11:44:15): message above repeats 318 times.
logger (13.12.2020 11:44:42): station 1 (AirLink), unexpected 0 bytes.
logger (13.12.2020 11:44:43): disconnect station 1 (AirLink): response without data
logger (13.12.2020 11:44:46): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 11:45:14): connect station 1 (AirLink via SW Driver).
logger (13.12.2020 11:45:15): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 12:05:54): message above repeats 76 times.
logger (13.12.2020 12:05:57): station 1 (AirLink), unexpected 0 bytes.
logger (13.12.2020 12:06:00): disconnect station 1 (AirLink): response without data
logger (13.12.2020 12:06:26): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 12:06:30): connect station 1 (AirLink via SW Driver).
logger (13.12.2020 12:07:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (13.12.2020 12:11:27): message above repeats 24 times.
NanoSD Error + not responsive
- jasonmfarrow
My station has been offline for a while this morning with this in the log:
- jasonmfarrow
Re: Database error??
I had to do a full power-off & battery-out reset to get the NanoSD back into service. I've lost three hours of data. Here's the various SW levels etc.
Also the Davis Vue is working fully as is the Davis Airlink (IP address is unchanged). Something's amiss somewhere.Platform: Meteobridge NANO SD
RAM: 125 MB total, 45 MB free (63% used)
Storage: swissbit SLC, 897 MB total, 841 MB free (6% used, 45.4 yrs)
SW Version: Meteobridge 5.0 (Dec 6 2020, build 3662), FW 1.4
