Nano Bad Gateway. **solved**
Car54
Post by Car54 »
I've been successfully using a MeteoBridge from Ambient Weather this past year. I'm trying to upgrade to the Nano. I'm able to perform the setup procedure, assign the WiFi network and reboot. The Nano webpage appears, requesting agreement to the License. After selecting the check box and then "Save and Apply", I'm presented with the full set of tabs. When I next select any tab (e.g. System), the Nano immediately returns a "Bad Gateway" error message. From that point on, the website is not displayed.
I can still connect with ssh. I'm not sure what to look for. In /tmp/log there is a timeout-wnet.log file that contains the text 'https://api.ambientweather.net/endpoint'.
ifconfig shows
apcli0 Link encap:Ethernet HWaddr BA:D8:12:00:58:C4
inet addr:192.168.1.181 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::b8d8:12ff:fe00:58c4/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:2564 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eth0 Link encap:Ethernet HWaddr B8:D8:12:60:58:C4
inet addr:192.168.168.1 Bcast:192.168.168.255 Mask:255.255.255.0
inet6 addr: fe80::bad8:12ff:fe60:58c4/64 Scope:Link
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:58 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:8233 (8.0 KiB)
Interrupt:5
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:208 errors:0 dropped:0 overruns:0 frame:0
TX packets:208 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:23538 (22.9 KiB) TX bytes:23538 (22.9 KiB)
and ip -r shows
default via 192.168.1.1 dev apcli0 src 192.168.1.181
192.168.1.0/24 dev apcli0 scope link src 192.168.1.181
192.168.1.1 dev apcli0 scope link src 192.168.1.181
192.168.168.0/24 dev eth0 scope link src 192.168.168.1
Any ideas?
VP2+ Nano SD & Pro2
Re: Nano Bad Gateway
Can you provide me a remote login link? Having that I might also login via SSH and check what throws the error.
Please send credentials to "info(at)meteobridge.com".
Car54
Post by Car54 »
Will do.
VP2+ Nano SD & Pro2
Analysis turned out that there is a hardware issue with the SD card.
