I added a new SD Card (SDSDQED-064G-XI) a few days ago and today in morning I got some io errors (see below)
I rebooted nano and now it states that the SD Card is not on the list of supported cards
Hinweis: Eingesetzte microSD-Karte ist nicht auf der Liste der von der NANO akzeptierten industriellen SLC Modelle (WD64G).
rescue download to be started
rescue download ended
LED path: /sys/class/leds/vocore2:fuchsia:status
accepted microSD card: WD64G
Meteobridge NANO storage, device /dev/mmcblk0p1.
start format SD card
format SD card failed!
start filesystem check: /dev/mmcblk0p1
/dev/mmcblk0p1 is in use.
filesystem is fine
database (03.01.2021 05:05:11): rollback on insert forced (1) (storemin): thb0temp
database (03.01.2021 05:05:12): cannot insert into 'thb0temp_min' (after 0 tries in 1ms): disk I/O error (10)
database (03.01.2021 05:05:12): rollback on insert forced (1) (storemin): thb0temp
database (03.01.2021 05:05:13): cannot insert into 'thb0temp_min' (after 0 tries in 1ms): disk I/O error (10)
database (03.01.2021 05:05:13): rollback on insert forced (1) (storemin): thb0temp
database (03.01.2021 05:05:14): cannot insert into 'thb0temp_min' (after 0 tries in 1ms): disk I/O error (10)
database (03.01.2021 05:05:14): rollback on insert forced (1) (storemin): thb0temp
database (03.01.2021 05:05:15): cannot insert into 'thb0temp_min' (after 0 tries in 1ms): disk I/O error (10)
database (03.01.2021 05:05:15): rollback on insert forced (1) (storemin): thb0temp
database (03.01.2021 05:05:16): cannot insert into 'thb0temp_min' (after 0 tries in 1ms): disk I/O error (10)
database (03.01.2021 05:05:16): rollback on insert forced (1) (storemin): thb0temp
database (03.01.2021 05:05:17): cannot insert into 'thb0temp_min' (after 0 tries in 1ms): disk I/O error (10)
database (03.01.2021 05:05:17): rollback on insert forced (1) (storemin): thb0temp
database (03.01.2021 05:05:18): cannot insert into 'thb0temp_min' (after 0 tries in 1ms): disk I/O error (10)
database (03.01.2021 05:05:18): rollback on insert forced (1) (storemin): thb0temp
clientraw (03.01.2021 05:05:49): cannot prepare select on read_table 'rain0total_day' (after 100 tries in 9061ms): unable to open database file
clientraw (03.01.2021 05:05:58): cannot prepare select on read_table 'rain0total_month' (after 100 tries in 9058ms): unable to open database file
clientraw (03.01.2021 05:06:07): cannot prepare select on read_table 'rain0total_year' (after 100 tries in 9058ms): unable to open database file
clientraw (03.01.2021 05:06:16): cannot prepare select on read_table 'rain0rate_day' (after 100 tries in 9058ms): unable to open database file
clientraw (03.01.2021 05:06:25): cannot prepare select on read_table 'rain0total_day' (after 100 tries in 9058ms): unable to open database file
clientraw (03.01.2021 05:06:34): cannot prepare select on read_table 'th0temp_day' (after 100 tries in 9058ms): unable to open database file
clientraw (03.01.2021 05:06:43): cannot prepare select on read_table 'th0temp_day' (after 100 tries in 9058ms): unable to open database file
