Meteobridge Nano SD to Davis Vantage Pro 2 Connection Problem
brentener
Post by brentener »
I have a Meteobridge Nano SD installed in the Davis Vantage Pro 2. From there, I send the data to WSWIN. I now found that the data has some errors.
I have posted a screenshot showing that at 2:05am the value for the pressure is 0. The same happens to the humidity values. I have also posted a screenshot from WSWIN showing some errors (I have corrected some of them). The console is place at around 8 m from the sensors. The station is relatively new (from july 2020). So the batteries shouldn't be an issue.
Thanks for any help !
Brentener Luc
Screenshot 2021-01-04 at 17.20.19.png (160.1 KiB) Viewed 4282 times
Captura de pantalla 2021-01-04 a las 19.10.36.png (172.75 KiB) Viewed 4282 times
