It has done this since day one (~ 2 years ago) and across every update.
Any ideas what this message is about and how to disable this sensor?
oled (04.01.2021 21:18:50): process started.
test5m (04.01.2021 21:21:08): weathernet daemon stalled, will be restarted now.
wnetd  (04.01.2021 13:21:08): process started.
test5m (04.01.2021 21:21:08): logger stalled, will be restarted now.
system (04.01.2021 21:21:08): stop of logging process initiated.
wnetd  (04.01.2021 13:21:08): send data thread started (pid:2688 tid:2690)
database (04.01.2021 13:21:13): process started.
database (04.01.2021 13:21:13): Content of RAM database restored.
system (04.01.2021 13:21:17): start of logging process initiated.
logger (04.01.2021 13:21:18): databases connected. Update interval 3600 seconds.
logger (04.01.2021 13:21:18): data logger (version 5.1e, build 14221) started.
logger (04.01.2021 13:21:19): connect station 0 (Meteostick Vantage via USB serial).
logger (04.01.2021 13:21:19): connect station 9 (System Data via Plug-in).
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), transmitter 2 registered as Wind
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), Meteostick Version 2.5.2
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), debug off
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), verbose off
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), filter on
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), rx threshold set to -75db
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), listening to transmitter 1 2
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), bandwidth narrow
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), chip authentication ok: 14
logger (04.01.2021 13:21:21): station 0 (Meteostick Vantage), frequency band 915MHz (US)
logger (04.01.2021 13:21:22): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (04.01.2021 13:21:22): services paused.
database (04.01.2021 13:21:52): database sync done (48 tables, 192/2016 writes).
logger (04.01.2021 13:23:19): give up waiting for sensors after 120 secs.
logger (04.01.2021 13:23:19): services activated.
logger (04.01.2021 13:32:01): Bad thb9(9) sensor data, "pressure x10" (-2607) out of range [4000:13000]
logger (04.01.2021 13:34:30): message above repeats 5 times.
logger (04.01.2021 13:35:01): Bad thb9(9) sensor data, "pressure x10" (-2608) out of range [4000:13000]
logger (04.01.2021 13:51:02): message above repeats 32 times.
logger (04.01.2021 13:51:31): Bad thb9(9) sensor data, "pressure x10" (-2609) out of range [4000:13000]
logger (04.01.2021 13:53:01): message above repeats 3 times.
logger (04.01.2021 13:53:30): Bad thb9(9) sensor data, "pressure x10" (-2608) out of range [4000:13000]
logger (04.01.2021 13:54:01): Bad thb9(9) sensor data, "pressure x10" (-2609) out of range [4000:13000]
logger (04.01.2021 13:54:30): Bad thb9(9) sensor data, "pressure x10" (-2608) out of range [4000:13000]
logger (04.01.2021 13:56:30): message above repeats 4 times.
logger (04.01.2021 13:57:01): Bad thb9(9) sensor data, "pressure x10" (-2607) out of range [4000:13000]
logger (04.01.2021 13:59:30): message above repeats 5 times.
logger (04.01.2021 14:00:01): Bad thb9(9) sensor data, "pressure x10" (-2606) out of range [4000:13000]
logger (04.01.2021 14:02:01): message above repeats 4 times.
logger (04.01.2021 14:02:30): Bad thb9(9) sensor data, "pressure x10" (-2605) out of range [4000:13000]
logger (04.01.2021 14:04:30): message above repeats 4 times.
logger (04.01.2021 14:05:01): Bad thb9(9) sensor data, "pressure x10" (-2604) out of range [4000:13000]
logger (04.01.2021 14:07:29): message above repeats 5 times.
logger (04.01.2021 14:08:02): Bad thb9(9) sensor data, "pressure x10" (-2603) out of range [4000:13000]
logger (04.01.2021 14:15:01): message above repeats 14 times.
logger (04.01.2021 14:15:29): Bad thb9(9) sensor data, "pressure x10" (-2602) out of range [4000:13000]
logger (04.01.2021 14:29:01): message above repeats 27 times.
logger (04.01.2021 14:29:30): Bad thb9(9) sensor data, "pressure x10" (-2601) out of range [4000:13000]
logger (04.01.2021 14:41:30): message above repeats 24 times.
logger (04.01.2021 14:42:01): Bad thb9(9) sensor data, "pressure x10" (-2602) out of range [4000:13000]
logger (04.01.2021 14:50:01): message above repeats 16 times.
logger (04.01.2021 14:50:30): Bad thb9(9) sensor data, "pressure x10" (-2603) out of range [4000:13000]
logger (04.01.2021 15:06:30): message above repeats 32 times.
logger (04.01.2021 15:07:01): Bad thb9(9) sensor data, "pressure x10" (-2604) out of range [4000:13000]
logger (04.01.2021 15:08:29): message above repeats 3 times.
logger (04.01.2021 15:09:01): Bad thb9(9) sensor data, "pressure x10" (-2603) out of range [4000:13000]
logger (04.01.2021 15:13:01): message above repeats 8 times.
logger (04.01.2021 15:13:30): Bad thb9(9) sensor data, "pressure x10" (-2604) out of range [4000:13000]
logger (04.01.2021 15:27:01): message above repeats 27 times.
logger (04.01.2021 15:27:30): Bad thb9(9) sensor data, "pressure x10" (-2605) out of range [4000:13000]
logger (04.01.2021 15:28:01): Bad thb9(9) sensor data, "pressure x10" (-2604) out of range [4000:13000]
logger (04.01.2021 15:28:29): Bad thb9(9) sensor data, "pressure x10" (-2605) out of range [4000:13000]
logger (04.01.2021 15:35:30): message above repeats 14 times.
logger (04.01.2021 15:36:01): Bad thb9(9) sensor data, "pressure x10" (-2606) out of range [4000:13000]
logger (04.01.2021 15:47:01): message above repeats 22 times.
logger (04.01.2021 15:47:30): Bad thb9(9) sensor data, "pressure x10" (-2607) out of range [4000:13000]
logger (04.01.2021 16:06:30): message above repeats 38 times.
logger (04.01.2021 16:07:02): Bad thb9(9) sensor data, "pressure x10" (-2608) out of range [4000:13000]
logger (04.01.2021 16:32:02): message above repeats 50 times.
logger (04.01.2021 16:32:30): Bad thb9(9) sensor data, "pressure x10" (-2609) out of range [4000:13000]
logger (04.01.2021 16:33:01): Bad thb9(9) sensor data, "pressure x10" (-2608) out of range [4000:13000]
logger (04.01.2021 16:34:30): message above repeats 3 times.
logger (04.01.2021 16:35:01): Bad thb9(9) sensor data, "pressure x10" (-2609) out of range [4000:13000]
logger (04.01.2021 17:09:01): message above repeats 68 times.
logger (04.01.2021 17:09:30): Bad thb9(9) sensor data, "pressure x10" (-2610) out of range [4000:13000]
logger (04.01.2021 17:10:01): Bad thb9(9) sensor data, "pressure x10" (-2609) out of range [4000:13000]
logger (04.01.2021 17:10:30): Bad thb9(9) sensor data, "pressure x10" (-2610) out of range [4000:13000]
logger (04.01.2021 17:17:01): message above repeats 13 times.
