Problem of data loss and block of the meteobridge NANO SD
piegarometeo
Post by piegarometeo »
Hello.
We have a problem of this type, every time the power fails or the internet does not work, I lose all the data of the weather station due to the outage as the outages last at least 8h, with the Wheater Display in these cases as soon as the PC was restarted they were downloaded all the data of the console datalogger that were going to update the portal and other sites, with the meteobridge this does not seem to happen when the router is reactivated, so I would like to know what operation should be done to transfer all the missing data to the portal (I have a meteotemplate http://piegarometeo.it/), I find it impossible that this possibility is missing since it is essential to keep the historians continuous and updated.
Unfortunately we also have a problem with the meteobridge blocking, it continues with a frequency 1/2 times a month, it happens with the red LED on as if it worked correctly, to unlock the console it is necessary to turn off the console since it does not access via wifi, it also happens to the my friend who took the Meteobridge NANO SD like me.
Thanks for the sure support
Re: Problem of data loss and block of the meteobridge NANO SD
Meteobridge does not read out the data the Davis logger might have stored internally. Putting the Meteobridge onto a cheap PSU will solve this.
