Nano SD Installation problems. **solved**
bootsmann
Post by bootsmann »
Hallo,
ich betreibe eine Davis vantage vue (bisher mit meteohub/meteoplug +raspi ohne Probleme) und wollte zur nano sd wechseln.
Die Installation nach Anleitung endet mit einem schnellen Dauerblinken der roten LED und der IP-Aufruf (192.168.169.1) bringt einen Time-out Error.
Auch ein IP-Scan findet die IP nicht. Mehrere Resets blieben ebenfalls ohne Erfolg. Hat jemand eine Idee dazu?
I am running a Davis vantage vue (so far with meteohub/meteoplug +raspi without problems) and wanted to switch to the nano sd.
The installation according to the instructions ends with a fast continuous flashing of the red LED and the IP call (192.168.169.1) brings a time-out error.
An IP scan does not find the IP either. Several resets were also unsuccessful. Does anyone have any ideas?
Thanks and greetings.
Andreas
Re: Nano SD Installation problems
Did you manage to login on the NANOs own WiFi access point and can you operate the WiFi settings from there?
bootsmann
Post by bootsmann »
...thank you, that was the solution! I had concentrated on the IP and overlooked WIFI.
Thank you.
Andreas
