Meteobridge RPI
iccb
Meteobridge RPI
Post by iccb »
I don't have any meteobridge products right now, but I have Davis Vantage Pro2 with weathercat software.
If I start use meteobridge RPI and use 32Gb card, can I store my history data in 5 minute interval?
I have data from 2013 and would like to convert this somehow to meteobridge.
I use Davis usb data logger right now. I wonder does meteobridge work with Meteo-pi logger? https://www.scaledinstruments.com/shop/ ... /meteo-pi/
Re: Meteobridge RPI
import of data for weathercat is currently not supported. You might convert data your own into one of the supported formats.
Mete-Pi logger from Poland is not supported. Too much of a niche product.
You can store data in per-minute or per-hour base resolution. Please be aware that you need one of the tested SLC microSD cards.
When going hourly 2GB will be fine, when going per-minute I would recommend 16GB.
Regards,
Boris
iccb
Re: Meteobridge RPI
Post by iccb »
Hi Boris,
Thx for the answer!
I must convert my data to supported, that's ok. I have read a lot of these microSD cards in meteobridge and think that maybe I order that newly supported wd card from mouser.
I have data now in minute resolution, so it's ok then to have it continuing to be in per-minute resolution.
