TL-MR3020 has stopped uploading data...
rmccullough
Post by rmccullough »
This has happened on the 13th, 18th, 22nd, and today. Up until today a reboot would resolve whatever the issues were. Today is the first time that a reboot has not resolved the issue. After a reboot it will only upload data once.
no	Meteoplug Cloud:	2021-01-23 19:06:19 Success: 2021-01-23 19:06:18
Meteoplug Cloud (Live):	No live traffic to cloud
no	Weather Underground:	2021-01-23 19:10:20 Success: 2021-01-23 19:07:27
no	Home Weather Station:	2021-01-23 19:10:21 Success: 2021-01-23 19:07:27
no	CWOP:	2021-01-23 19:06:52 Success: 2021-01-23 19:06:41
HTTP Upload:	No HTTP traffic
no	MYSQL Upload:	2021-01-23 19:10:16 Success: 2021-01-23 19:07:14
Logger after a reboot:
wnetd  (23.01.2021 19:06:11): process started.
system (23.01.2021 19:06:11): start of logging process initiated.
wnetd  (23.01.2021 19:06:11): send data thread started (pid:2484 tid:2486)
logger (23.01.2021 19:06:12): historical data loaded (20 records).
logger (23.01.2021 19:06:12): data logger (version 5.1e, build 14277) started.
logger (23.01.2021 19:06:12): connect station 0 (Vantage via USB serial).
logger (23.01.2021 19:06:13): station 0 (Vantage), wakeup sent.
logger (23.01.2021 19:06:16): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (23.01.2021 19:06:16): services paused.
logger (23.01.2021 19:06:16): station 0 (Vantage), no need to update console date/time.
logger (23.01.2021 19:06:17): station 0 (Vantage), setup script executed.
logger (23.01.2021 19:06:17): station 0 (Vantage), internal logger activated.
logger (23.01.2021 19:06:17): station 0 (Vantage), syncing.
logger (23.01.2021 19:06:27): station 0 (Vantage), gettime request sent.
logger (23.01.2021 19:06:37): message above repeats 1 time.
logger (23.01.2021 19:06:37): station 0 (Vantage), no Vantage time offset.
logger (23.01.2021 19:06:37): station 0 (Vantage), eeprom request sent.
logger (23.01.2021 19:06:37): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (23.01.2021 19:06:37): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (23.01.2021 19:06:37): station 0 (Vantage), firmware version request sent.
logger (23.01.2021 19:06:37): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (23.01.2021 19:06:37): station 0 (Vantage), no reading of Vantage's internal logger.
logger (23.01.2021 19:06:41): sensors are now providing data.
logger (23.01.2021 19:06:41): services started.
It is getting live data from the station:
#	Sensor	Signal	Metric Data	Imperial Data
0	Outdoor	23 sec	2.3°C 90% (dew 0.8°C, heat 2.3°C)	36.1°F 90% (dew 33.4°F, heat 36.1°F)
0	Wind	1 sec	0.0m/s (avg 0.0m/s) 117° ESE	0.0mph (avg 0.0mph) 117° ESE
0	Rain	3 sec	rate 0.0mm/h	rate 0.00in/h
0	Indoor	39 sec	20.4°C 45% 1017.9hPa (1008.3hPa)	68.7°F 45% 30.06inHg (29.78inHg)
I was on the most up to date SW but tried rolling back to 4.4. But nothing changed.
Here's the current system info. I do notice that the buffer slowly rises over time.
Platform:	TL-MR3020   (plus USB hub)
RAM:	29364 kB total, 3256 kB free (88% used)
SW Version:	Meteobridge 5.1 (Jan 18 2021, build 14277), FW 1.4
Uptime:	0 hours, 9 minutes    Buffer: 77 items (8%)
Re: TL-MR3020 has stopped uploading data...
Going back to former version anytime any problem occurs seems to have evolved as a standard procedure. :roll: I do not recommend that.
I share your idea that a creeping buffer fill up might be the root cause. Do you have a combination of fast firing uploads with retry options? This would be my first look. When data send commands stack up in the buffer Meteobridge might be occupied so much to get that sent that current transfers are put into the queue for being handled later.
rmccullough
Noted about the downgrading... It didn't seem to make anything worse though. I'm back on the latest version now.
I had WUnderground set to retry 5 times, Home Weather Station and CWOP set to 10. All were set to upload at the fastest speed possible.
To test I set them all to no retries then restarted. No change.
Now I just tried removed all weather networks, rebooted and checked the buffer. It wasn't going up. Which I expected.
So I went ahead and added WUnderground back and set it to 5 second upload and no retries. Now the buffer is starting to fill up again and the upload status just said "No weather network traffic". So I rebooted. Now it says:
Weather Underground:	2021-01-24 11:16:23 Error: 2021-01-24 11:16:19 wget: unable to resolve host address 'rtupdate.wunderground.com' (no more tries)
I can ping that URL from my computer:
C:\Users\Ryan>ping rtupdate.wunderground.com
Pinging prod-pws-ng-546567-997b58a668d15d562a6bed58ea7c5f9e-0001.us-south.containers.appdomain.cloud [169.60.133.174] with 32 bytes of data:
Reply from 169.60.133.174: bytes=32 time=68ms TTL=54
Reply from 169.60.133.174: bytes=32 time=67ms TTL=54
Reply from 169.60.133.174: bytes=32 time=70ms TTL=54
Ping statistics for 169.60.133.174:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 67ms, Maximum = 70ms, Average = 68ms
Now there is something else strange happening. The WUnderground site for my station has data for most of last night. Including times that I checked it when it was not reporting anything... I also noticed that the only time that WUndergound says my station is offline is when my meteobridge is off/rebooting.
rmccullough
Well it appears to be working fine now... I'm going to slowly add the weather networks back and see what happens.
