Wind data on meteoplug
Neco
Post by Neco »
Meteoplug does not receive any wind data (or wrong data?) from my MB PRO since around one month. Could this be a bug or is it a meteoplug problem?
Re: Wind data on meteoplug
You give close to zero information. What did you check?
Sensor name? Is it available on the Meteobridge? etc.
Please come back when you did your own inspection.
Neco
Post by Neco »
Everything working perfect on MB PRO, there is wind direction as well as wind speeds. However, somehow these measurements are not sent to meteoplug correctly. While meteoplug shows every other measurements (temp, hum), there is no data shown for wind (direction, speed).
Take a look into wind data on meteoplug:
2021-01-25 08:37:06 wind0 313° 1.4m/s -53.0m/s -0.2°C
2021-01-25 08:37:09 wind0 313° 0.9m/s -53.0m/s 0.7°C
There are negative values for wind speed, maybe that is what causes the problem. Could it be a MB PRO sending bug?
Neco
Post by Neco »
Any ideas? The problem is still there...
What kind of station?
Any mappings in Meteobridge?
Meteoplug account name to check your findings?
Can you give me remote access to your Meteobridge? Otherwise I doubt we will get anywhere with these kind of reports...
