MB Pro - realtime.txt neither created nor sent by FTP **solved**
Gyvate
Post by Gyvate »
Following all available instructions for creating and sending the realtime.txt file created by the realtime.txt template failed in both my MB Pro.
FTP server installed, test file successfully sent - however selecting the template:realtime.txt and entering path + filename with the URL doesn't produce any result.
The exactly same constellation set up in my RPi4 is successful.
What's wrong with the realtime.txt file generation from the template and the forwarding (FTP upload) in the MB Pro (MB Pro 1, build 14236; MB Pro 2, build 14308) ??
Re: MB Pro - realtime.txt neither created nor sent by FTP
What does your Path/File syntax look like? Are you including the User & Password in this syntax?
Gyvate
Post by Gyvate »
