I'm new here. I have installed a test version on a Raspberry 3b. My USB interface is recognized under weather station and can also be selected. If I then go to sensors, I cannot select a sensor. For example, if I go to wind0 and it does not save it. No data is displayed either.
When I try to use a PC and another program, data arrives. What can that be?
best regards
Timo
No connection Vantage 2 pro
Re: No connection Vantage 2 pro
Are you using an approved SLC SD card? What does the top section of the System / Information tab show for storage?
Meteobridge RPI | GW1000
