I am writing a template to collect yearly data and have discovered a few problems I hope somebody will be able to help me with.
[th0temp-ymin.1: ] returns the all-time minimum no matter what year I explore while at the same time [th0temp-ymintime.gh: ]/[th0temp-ymintime.ef: ] returns the correct date the mimum temperature occured in each year I am exploring. I have no problems with the yearly average or max or the min for other parameters.
[wind0maxdir-max.0:-] returns the correct value in degrees of the wind direction in each month or each day. However, [wind0maxdir-ymax.0:-] does not return the value in degrees of the maximum wind gust of the year. It simple gives the highest value of wind gust max measured. For example, the highest wind gust of 60 mph was measured in February and had a direction of 234° but January had a max wind gust of only 40 mph from the direction 356° and [wind0maxdir-ymax.0:-] returns the value of 356 and not 234°, which is the direction of the highest wind gust of the year.
What am I doing wrong?
regards
Template problems
Re: Template problems
Hello -
Although you dont state what platform you are using I am thinking this will get you what you are looking for the temps:
and you would use something similar for your wind data:
Have a read here under the Metebridge PRO Additons:
https://www.meteobridge.com/wiki/index.php/Templates
g
[th0temp-min@Y1=F]%20[th0temp-mintime@Y1.gh]%20[th0temp-mintime@Y1.ef]
[wind0maxdir-max@M1]
g
Thanks for your help.
[th0temp-min@2020],[th0temp-mintime@2020.gh]/[th0temp-mintime@2020.ef] and [wind0maxdir-max@2020] give me the correct data for 2020 so I can adjust this for any year I need.
I am using Meteobrige NanoSD and I was not aware that I could use the specific additions for PRO (I thought they would not work for Nano SD).
regards
regards
