Export, MB Pro, not working as exspected, - pls.help ** Solved **.
krischj
Post by krischj »
HI, pls help
I love my new MB Pro, a fantastic pcs of kit. However yesterday evening me and MB had our first "falling out" :D
I was writing a an export-template, and I can't make it work, - NO WAY!
Template:
# Standard CSV template WIND
$# date, time, avg wind speed[m/s], avg wind speed[km/h], winddir degress, winddir direction
[YYYY]-[MM]-[DD],[hh]:[mm],[wind0wind-avg.1:--],[wind0wind-avg=kmh.1:--],[wind0dir-avg.0:--],[wind0dir-avg=endir.5:-----]
Result:
2021-03-16,00:00,1.6,5.6,338,338.00000
2021-03-16,01:00,1.6,5.8,342,342.00000
2021-03-16,02:00,2.0,7.0,339,339.00000
2021-03-16,03:00,1.6,5.9,339,339.00000
2021-03-16,04:00,1.2,4.2,352,352.00000
As you can see, using Converters works fine - EXCEPT FOR the "endir", it is being ignored completely by the export.
No way I can make this "endir" work, so pls help.
It's OK to point out to me that I have missed something obvious, and indicating that my brain needs a server service check, as long as you point me in right direction :lol:
/kris
Re: Export, MB Pro, not working as exspected, - pls.help
endir produces 1 of 16 points of the compass as text so the .5 is not applicable
Try the following [wind0dir-avg=endir:-----]
krischj
Post by krischj »
Thx, tried that, and now once again.
result:
2021-03-16,16:00,1.6,5.9,338,338.0
2021-03-16,17:00,1.4,4.9,341,341.0
2021-03-16,18:00,0.5,1.7,326,326.0
2021-03-16,19:00,0.1,0.3,324,324.0
2021-03-16,20:00,0.0,0.0,324,324.0
2021-03-16,21:00,0.0,0.0,326,326.0
"endir" is just being ignored
/kris
krischj
Post by krischj »
BTW
.5 should be applicable according to: Templates, Decimals
When a number is given instead of a substring qualifier, then the number defines the number of characters the resulting string is padded to. When the number is smaller than the string length, then only rightmost characters remain, otherwise the string is added with leading blanks to make it's size fit. When the number is negative, then string is cut on the right side resp. trailing blanks are added. Example: Assume that wind direction is "ENE" then :[wind0dir-act=endir.5]:[wind0dir-act=endir.-5]: will result into : ENE:ENE :
Change the avg to act
Need to confirm if avg is a valid option for wind direction?
[wind0dir-act=endir:-----]
krischj
Post by krischj »
"act" will not produce any result "back in time"
result.
2021-03-16,19:00,0.1,0.3,324,-----
2021-03-16,20:00,0.0,0.0,324,-----
2021-03-16,21:00,0.0,0.0,326,-----
2021-03-16,22:00,0.0,0.0,326,-----
"act" works fine this end, I am simply using it in a Email header but the context should be the same one would think
krischj
Post by krischj »
Well, as you can see i dosen't. what you see is the result of this:
[YYYY]-[MM]-[DD],[hh]:[mm],[wind0wind-avg.1:--],[wind0wind-avg=kmh.1:--],[wind0dir-avg.0:--],[wind0dir-act=endir:-----]
I belive there is a fault somewhere..
/kris
krischj
Post by krischj »
Any body having ideas?
//kris
krischj wrote: Wed Mar 17, 2021 12:10 am Well, as you can see i dosen't. what you see is the result of this:
/kris
"-act" is not defined for exports. What should "actual" mean when you iterate through data in the past? Try "-avg" instead.
krischj
Post by krischj »
yes, that was what I replied ti Mattek, pls see my inital posting, That is my actual issue.
//kris
I tried "[wind0dir-val=endir:-----]" within an export definition and it works, same with "[wind0dir-avg=endir:-----]".
No idea what issue you are talking about.
admin wrote: Thu Mar 18, 2021 12:03 am I tried "[wind0dir-val=endir:-----]" within an export definition and it works, same with "[wind0dir-avg=endir:-----]".
Just checked endir in the body of an email ok but running both the above in an export template I get numeric values for both, not alpha direction?
krischj
Re: Export, MB Pro, not working as exspected, - pls.help. **solved**
Post by krischj »
Hi Mattk,
Yes, that's exatly my issue, "endir" is being "ignored" un export.
//kris
krischj
Post by krischj »
Hi Mattk,
Template:
Result:
