Hi to everyone!
I have a meteobridge NANO SD to collect datas from my Davis Vantage Pro 2 in the city of Verona, Italy.
I was trying to figure out how to download, in txt or csv file, the daily average data of solar radiation but I couldn't. I found all the other parameters such as temperatures, humidity etc through the NOAA reports but not the solar radiations
Can anyone help me?
Thanks so much,
Simone
Download solar radiation data from meteobridge Nano SD. **solved**
Re: Download solar radiation data from meteobridge Nano SD
Does [sol0rad-davg:1] not work ?
That would be the expression to choose as per the wiki (- templates).
You can verify the result by adding the hourly average values which are not equal 0 from the history of the sol0rad selector at a given day and divide them by the same number of hours where there are occurrences (values) greater than 0.
E.g. if from 08:00 - 18:00 you have values in the history of the sol0rad selector different from zero, add the average values (1st line) and divide the result by 11.
The result should be +/- the same as the value from [sol0rad-davg:1] in a template export.
I probably can't download because I'm not very experienced with meteobridge, sorry for that
If I go on edit data I see solOrad (fig 1). When I go on export data (fig 2) I see only the "classical" NOAA and there isn't the solar radiation inside the file.
you need to create your own customized export
below you find an example composed by me for almost all available sensors
You can save the example between the -------------- as a normal text file in the Meteobridge ../data/template directory under the name
all-sensors-iso-mod.exp
then you can select it and use it / test it
the result will be in the ../data/export directory
you can also remove the headers and sensors which you don't need and save the remaining ones under a different name in the same directory, too
# modified Standard CSV template with data in metric units
$# date, time, temperature[C], humidity[%], dew point[C], sealevel pressure[hPa], avg wind speed[m/s], gust speed[m/s], winddir, rainfall[mm], Solar [W/m2], PM25(1) [ug/m3], PM25(2), extra-temp1 [°C], extra-hum1 [%], extra-temp2 [°C], extra-hum2 [%], extra-temp3 [°C], extra-hum3 [%], extra-temp4 [°C], extra-hum4 [%],soil moisture (1) [%], soil moisture (2) [%], soil moisture (3) [%], soil moisture (4) [%], soil moisture (5) [%], lightning total, lightning distance, lightning energy
[YYYY]-[MM]-[DD],[hh]:[mm],[th0temp-avg:],[th0hum-avg.0:],[th0dew-avg.1:],[thb0seapress-avg.1:],[wind0avgwind-avg.1:],[wind0wind-max.1:],[wind0dir-avg.0:],[rain0total-sum.1:], [sol0rad-avg.2:], [air1!0pm-avg.1:], [air1pm-avg.1:], [th1temp-avg.1:], [th1hum-avg.1:], [th2temp-avg.1:], [th2hum-avg.1:], [th3temp-avg.1:], [th3hum-avg.1:], [th4temp-avg.1:], [th4hum-avg.1:],[th20hum-avg.0:], [th21hum-avg.0:], [th22hum-avg.0:], [th23hum-avg.0:], [th24hum-avg.0:], [lgt0total-avg.0:], [lgt0dist-avg.0:], [lgt0energy-avg.0:]
It works! Thank you very much
