NanoSD upload WLCloud - Heat & Chill transposed? **solved**
The Wind Chill and Heat Index values appear as expected in the NanoSD Historical data
but appears reversed once uploaded? Anybody else notice this anomaly?
Re: NanoSD upload WLCloud - Heat & Chill transposed?
And some further comparison today showing no issues with Archive data be it downloaded from WL or Envoy/NanoSD direct
Bulletin display still shows Heat & Chill transposed
Summary page shows Current heat & Chill transposed BUT Daily values are the correct way around which may be coming from the separate Arvhive data upload and not the uploaded PHP file from the NanoSD??
Is it a Meteobridge only issue or also happening when using other tools to upload data to WL?
admin wrote: Fri Mar 26, 2021 10:14 am Is it a Meteobridge only issue or also happening when using other tools to upload data to WL?
Appears to be related to the NanoSD/WLcloud upload, I am also uploading WL from the same ISS feed with WLIP and that appears ok. There is obviously a different link between archive data and Wlcloud when used in certain WL bulletins and summary links
I can change heat and chill values when transmitting to WL. When you send me a MAC we can try on this in beta first.
Build 3809 appears to have Wind Chill and Heat Index aligned in regard WLCloud uploads
Re: NanoSD upload WLCloud - Heat & Chill transposed? **solved**
Great. So I will release this with next update.
