Export issue: sensor "wind0maxdir" can't be exported
krischj
Post by krischj »
I ran into an issue with sensor "wind0maxdir". It can't be used in export templates. Trying to do so returns "nothing"
[wind0maxdir.0:--]
returns:"--"
I think there must be a fault somewhere, Anyone having ideas.
//kris
Re: Export issue: sensor "wind0maxdir" can't be exported
Yes the fault is in how you are applying the variable which has a typical structure of [sensor-selector=convertor.decimals:replacement].
[windomaxdir.0:--] does not have a selector hence will return nothing.
You need to review the template structure https://www.meteobridge.com/wiki/index.php/Templates noting that wind0maxdir only supports the Selectors hmax, dmax, ydaymax, mmax, ymax and amax
krischj
Post by krischj »
right, wind0maxdir-max works, thx.
It seems not logical at first max/max, and looking at the raw data from sensor wind0maxdir, unlike otjer sensors it does not have min, avg, max, so I didn't thought of using a selector.
however, fixed, - thx a lot and happy easter.
//kris
