Vue/Meteobridge Nano not logging
Frogwell
Post by Frogwell »
Evening All,
I've recently upgraded to a Vue / Meteobridge Nano setup which I've got running and uploading fine to Wunderground and PWS, and also transferring live data to Cumulus but can't seem to get it to transfer overnight logged data to Cumulus.
I have a couple of fine offset stations which I've been running with Cumulus for years, and the logged overnight data would just transfer in the morning when I switched my computer on and then transfer live throughout the day. It's not the Nano SD I have, but should the standard Nano not have some limited logging ability?
Re: Vue/Meteobridge Nano not logging
Did. you read the wiki? When you are mentally stuck to cumulus, you might be wrong here.
BigAlT
Post by BigAlT »
It seems to me that since the Nano is online 24/7 that there is no need for overnight data since it’s sending Iive data 24/7 as well. The main design goal of the Meteobridge ( from the Wiki ) was to have a low cost low energy use system to upload data to the various weather networks 24/7 without the necessity of running a dedicated PC 24/7. As you were not running your PC 24/7 it had to upload overnight data when you booted it up in the morning. The Meteobridge Nano running 24/7 does not need to store any data having already uploaded it live. From the Wiki “ The fundamental difference compared to a regular NANO is that the NANO SD has 2 GB of permanent storage while the NANO just has 16 MB onboard flash mostly covered by the operating system and the application programs. Equipped with 2 GB the NANO SD can hold about 20 years of data. NANO SD holds data for last 72 hours in a per minute resolution and older data in a per hour resolution. “
As BigAIT is pointing out correctly. The NANO SD does not make use of the data archived in the console, it archives data on its own. NANO without local storage does not do data logging at all, it delivers to networks, which do the logging.
