issue fixes a bug in reading country information
zmarfak
Post by zmarfak »
I just upgraded my Nano SD.
There is no location by IP displayed.
2021-04-11 23_58_29-Clipboard.png (48.27 KiB) Viewed 4262 times
kind regards
Patrick
Re: issue fixes a bug in reading country information
That's not occurring for a NanoSD with 5.1 (Apr 10 2021, build 3819), FW 1.3 which was updated about 45 minutes ago
Even with the latest update, the IP-based location display also does not work for me.
Well that's interesting? I just checked this NanoSD I updated to this morning (7 hours 14 minutes ago) and all is Still well, MAC is ok, WANP IP is ok, Lat & Long is all good, in the Localization box, Location by IP: shows? but that's fairly normal.
Just to confirm it is 5.1 (Apr 10 2021, build 3819), FW1.3
Now the only other difference I can see is my FW is 1.3, zmarkaf FW is 1.4
yes, it is only cosmetic and not relevant for the Meteobridge functionality, but the firmware release notes say:
- fixes a bug in reading country information in "System - Information" tab.
If that is what is meant by it, then it does not work yet:
dcaysinger
Post by dcaysinger »
I also have this condition with Meteobridge 5.1 (Apr 10 2021, build 3819), FW 1.4
question mark for location IP.
Thank you
Just released update should fix this.
dcaysinger
admin wrote: Fri Apr 16, 2021 2:06 pm Just released update should fix this.
Build 3820 did solve this. Thank you.
I also can confirm, is fixed.
thanks Boris
zmarfak
Post by zmarfak »
Indeed Solved
